Joined 2009
Joined 2009
Dave D loves ‘em and it’s been years since I was brave enough to try Fostex again. My hearing has had some time to deteriorate so I may no longer find the treble too hot. A chance to play with Fostex is expected to be a pleasant trip down memory lane, to the days when Fostex was in vogue on the forum. I miss those days.
A replacement carburetor for my 5 KW generator. Day long or more power outages seem to be a weekly occurrence here now.
Hers is to hoping you beat Elsa with that generator job.
Certain vagueness? Over? Tell me it ain't so! 🙂
Depending on how high you are taking the woofers you may be forced to use several smaller drivers. For low frequency work, my best success has been with 10" drivers in combination, or single or dual 15" or 18" drivers of much higher quality that C-V drivers. The larger drivers must be rolled off lower of course! Every good system was an electronically crossed over with the amplifier directly driving the driver(s).
I found that 12" woofers were just an unhappy size. Too slow to cross over very high, and too close in price and box size to a 15" that out performed it. 8" drivers are also very good in groups.
-Chris
My Advent Maestro's use a 10" each.
When they rotted out I replaced them with a nice, non-rotting, and more robust driver that "digs even lower" and been pleased ever since.
A beautiful calibrator, she's a fine unit to service. I calibrated/serviced a few of these calibrators in my time. I think the work one had the cassette module but was never used. Exchanging the boards was the go in those days.A Fluke 5100B meter calibrator.
Weekly power outages!, are you sure it's not your power amps?power outages
New Weber charcoal grill 😀
I have a similar looking device - the B&K 4222 in pascal green, it is easier to say 'where's the weber?' than where's the anechoic chamber?
Monster at teh dollar tree.
Yes,$1 each ...
From the web: "excessive or repeated consumption can lead to cardiac and psychiatric conditions"
Flush the gas tank with that stuff.
Hi BKnut,
Thanks for that vote of confidence in the Fluke. I used the 5700A and the 5500A in the lab. This one has errors and will need some love before I can use it. Apparently the HV ranges don't work.
-Chris
-Chris
I have always done things out of order in my life, like becoming an electrical engineer, then getting an engineering degree. In this case I lived in Florida for 62 years, then retired and moved 1200 miles north.
In any normal year we would have arrived at the time share on Captiva Island in Florida yesterday, pretty much where Elsa is aimed, due there on Tuesday. We didn't get to go this year, so we should be pretty much out of Elsa's range.
The only amps I have been using in months are a 4 watt guitar amp and a 15 WPC UNSET. We had an unusually long and snowy winter last year. That brought some serious tree growth now. The foliage on the trees is thicker than I can remember, thick enough to kill all cell service here even without rain. So far every power outage has been blamed on "tree contact."
We have had three over night power outages this year. The 16 year old big generator died during the first. A "new" carb should arrive from Amazon today. For $17 I don't expect much but all I should really need is the gaskets, and maybe the float or valve.
Joined 2009
I knew the Antipodes were advanced when it came to the BBQ. Heck, some people don’t even use a meat thermometer, but you have a test lab at your disposal for ensuring that perfect steak
I'm very pleased to say the ELAC speakers I bought are damned good! There's far more LF than I expected - it's almost as good as the RC70 but the HF is subdued. Some people remove the tweeter grill. I'll let them "break in" a bit first.
Mag-lite,
For $5us.
For $5us.
the BBQ.
The first BBQ restaurant, wasn't a restaurant.
Twas a vacant lot, on Banks street,
In Kansas City.
Early in the morning, Henry Perry, would dig a hole,
Toss in some lumber, set it on fire.
Once that was burning well,
He would place the dead critter parts,
On the fire. With his sauce.
Then cover the whole thing with dirt.
About noon, every thing was ready.
Wrapped in newspaper, for 25 cents .
Looks like some of the details,
Have been removed, from wiki, >
Henry Perry (restaurateur - Wikipedia)
Biography of Henry Perry (1875-1940), Restaurateur | KC History
Tube amp chassis (big) from Hammond. Pig steel because it will be my prototyping monster chassis (ie it will end up like Frankenstein in a few years).
WIMA FKP1 caps and MKP caps
IEC socket, filter, switch and fuse all-in-one.
With this I can get moving. I still need to source a transformer from the UK but like everything this is a slow burner.
- Member Areas
- The Lounge
- And what did we buy today?
