Finally bought that roll of solder... 4885-454g from MG...
Free shipping from Sayal for people in Southern Ontario. SAYAL Electronics Home Page Redirect
The gear changes are much faster and firmer, I get a gear indicator in D and S.
It locks up quicker inn all gears and let me push the pedal much harder without downshifting. Now I get to use all that diesel torque.
Before, the transmission acted like I had a petrol engine and tried to get in to high revs as soon as I touched the throttle. Now it stays in the current gear and starts pulling hard instead.
I don't like automatic transmissions and was very annoyed by the way this gearbox behaved. I was left with two options: sell the car or do a MT conversion. After the xHP flash I can actually live with the handicap tranny.
I've never owned an automatic that was electronically controlled, but I have driven a BMW with flappy paddles. It was alright, but no substitute for the clutch Although, if you load it up first it's not too bad (brake stand).
Speaking of clutch, I'm going to have to replace it soon.
It's finally starting to slip once in a while at full throttle. Not bad though, 240000kms on it
If you want your new clutch to last longer, remove the CDV (clutch delay valve). It's installed to protect the drivetrain from bad drivers.
If you release the cutch quickly, it causes a delay so the fluid slowly flows out of the slave cylinder.
During quick gear changes, the clutch will slip a little before fully engaging.
Remove this and regain full control over your clutch.
I have removed it from my 118d. It has almost 220k on the meter and the clutch is still going strong.
Four dozen 0.022 uf FT1 Teflon caps arrived today.
And only a decade+ to find time to work with them. Mated below with a DA25TX00-08 in a temp PBS cast-off cabinet until sawing weather returns.
AFAIK the JX-92S group buy was one of the largest this forum ever had.
Trust me, you're light years ahead of me. I have 2 JX-92's, 2 G2Si's, 2 GW-1858's just waiting in boxes for me build whatever they're properly called, can't even remember the name of the design.
- Member Areas
- The Lounge
- And what did we buy today?
