Amp Camp Pre+Headphone Amp - ACP+
R4 sets the current of the J113 (Q3). The current should be around 10mA.
I assume R4 is 125 Ohm, not R15 as you mentioned.
Left channel current = 0.916V/125R=0.0073A = 7.3mA, close enough for the circuit to work.
Right channel current = 0.412V/125R=0.0033A = 3.3mA, too low, resulting in the voltage at R15 being too low, and therefore Q6 not functioning.
What needs to be done is R4 in the right channel to be reduced in value. This will be by trial and error. Try 50 Ohm or so first. Then measure the voltage drop across the resistor and do the calculation as above. The target current is 10mA.
Yes, production variation.
You can do the test as you had posted earlier and select a J113 that gives you 10mA, or if you have some resistors handy, just change the resistor.
The J113 is just a constant current source so the resistor change is not detrimental to the sound. Not having the 10mA current is detrimental to the sound. So changing the resistor to attain the 10mA will sound the same as finding a J113 that works with a 125R resistor for 10mA.
Interesting that this comes up again. I just received an assortment of resistors and some sockets, and so tested 10 - 125 ohms on my right channel. Previously it had not worked at 125 ohms, and did work with half that, about 62 ohms. Somewhere between 75 and 90 ohms it probably stopped working, though I didn't record the voltage at DC1. As I decreased resistance from 65 to 10 ohms the current rose from about 4.5mA to 7.2mA. At this point I tried some 3.3, 2.2, and 1 ohm resistors which gave 7.83, 8.05, and 8.4mA, respectively, two 1 ohm in parallel gave about 8.5mA as well. At this point I hooked up a source and made a set of rca speaker cables, and verified I got sound out of the right channel even with R4 shorted.
Meanwhile my left channel came in at 9.9mA with a 90 ohm resistor.
I finished my build of the ACP+ today and can report limited success. I haven't plugged in headphones and source yet, but voltages are looking good at roughly 8mA and 9mA per channel with 23.5 ohms for R4. I'll dial in the right values tomorrow and give it a listen!
I want to build the ACP+.
My problem is that I don't have part Q3 J113, but I have 2N7000 instead. I got the 2N7000 as equivalent part for the J113 from a local store. They told me in the store that the 3 pinouts are different and I can turn them around so that they match with the PCB.
J113 pintouts: D S G
2N700 pinouts: S G D
(When the printed side is on the front side.)
Is it possible to build the ACP+ with the 2N7000?
Hi guys so I ordered the parts following the BOM on post #661, I realised for R16 and R17 its 33.2 ohm, and the mouser prt number links to 33.2K ohms instead, is that intentional?
Also the BOM or Mr Pass's BOM doesnt include any part for R22 7.5k, is that not nessesary?
Lastly, I have these RCJ-053 CUI Devices | Mouser 香港, RCA jacks as per the #661 BOM, seems like the orientation of the pins dont fit the board like it should?
Thanks for your help!
