Amp Camp Amp - ACA
Ok Pico, I have it finished. I have 22.7vdc under load. Set bias at 11.42. This is after 1/2 hr. warm up and connected to 8 ohm speakers. Nothing on input.
For 22.7V power supply
Anything between 11.4 and 12V across Q1 seems good.
Here it is at 11.6V Vds across Q1
Good deal. Thanks for checking this. I have them set at 11.92. Seems to like it there. Runs cool for class a. I can hold my hand on the heatsinks after a hour warm up. I'm also glad I went with the linear supply. These sound better than the first set I built with the switching supply.
Joined 2007
My friend gave me his unwanted transformer rated at 12v-0-12v 50VA.
Can I use this underrated transformer for this ACA?
As I remember, a rule of thumb is to take a transformer rated at least twice the needed power. My 19V ACA dissipated 25 W per side. My high power 24V ACA dissipates 35W per side.
So your tranformer might be good for a single side 16V ACA. 16V might be not enough for good sound.
My stereo 24V ACA relys on a 250W, 2x18V trafo (which I had unused laying around) and I would not go below 150 W.
Best
Ernst
Seems to be a good choice and bring you close enough to the wanted 19V. The few more you will get won't degrade the sound.
Yes, I wish I could get the best sound of it.
By the way, according to original design, without modification like increasing the voltage and bias, how hot the heatsink will be? I ordered a heatsink from RS UK which rated at 0.29degC/W and the size is 150x200x15. I have ordered 2 pieces of this. Do you think I can fit 2 boards (left anf right channel) into 1 piece, so that I could save another piece.
