Amp Camp Amp - ACA
Hi - I can't see any BUTTON or FIELD where I enter a question in the ACA Forum and I can't find any explanation explaining how to post a question. I am typing this into 😛OST REPLY: or QUICK REPLY but I assume this field is to reply to post #8329. I have questions about the blue rear panel switch in the Build Guide. Thanks.
To post a new question or thread you use this in the appropriate forum. This show 'Pass Labs' selected:
Quick reply lets you add a reply to the thread you are viewing.
Post Reply is exactly the same but opens the advanced window to allow attachements as well. It just saves one button click over quick reply if you were intending adding attachments.
'Quote' in the post you want to reply to quotes that post in your reply. We don't encourage that if you are just adding a reply to the post above, or if it is obvious who you are replying to.
Hope that helps 🙂
I would expect the M2x specs to be pretty much the same as that for the M2 since
the difference is the ability to use different front end buffers.
The higher noise may be an issue if you use very sensitive speakers. I didn't have
any problem with my 90dB speakers. IIRC, my measured noise was about 300mV.
There is a brave man to comment on the operation of the amplifier from the maestro?
Pass ACA Class A Power Amplifier Review | Audio Science Review (ASR) Forum
One problem reviewing a DIY amp built by another person is that you don't know if amp is 100% up to spec. There are some of the findings in the review that makes me think it is a faulty amp/power supply.
I went to see what this website had to say—it's not worth the time. My impression was that the author didn't listen more than 10 - 30 seconds.
I dont think you need to listen for more than a few minutes to realise there is a lot distortion.
It's certainly not nasty sounding distortion and combined high Class A bias lends to nice organic sound but its very obvious if you are used to low distortion.
A cold and harsh sounding amp that still manages to measures very well may be less pleasant to listen to but I think this kind of amp is still letting you hear more of the music and less of the amp than something like ACA.
When I recommended "build one of each", I had in mind an ACA and another amp whose sonic description resembles the attached quote. A cold and harsh sounding amp that still manages to measure very well.
... combined high Class A bias lends to nice organic sound but its very obvious if you are used to low distortion.
