Alpha Nirvana 39w 8ohm Class A Amp
Here is the Alpha Nirvana v2 schematic with Hugh's latest tweaks:
attachment.php
Here is the behavior at clipping - notice how symmetric it is:
attachment.php
Here is the FFT for 8Vpp into 8ohms:
attachment.php
Here are the distortion components with 0.0039% THD:
Code:
Harmonic    Frequency     Fourier     Normalized     Phase      Normalized
 Number       [Hz]       Component     Component    [degree]    Phase [deg]
    1       1.000e+03    3.937e+00    1.000e+00       -0.68°        0.00°
    2       2.000e+03    1.538e-04    3.906e-05     -113.08°     -112.40°
    3       3.000e+03    8.049e-06    2.045e-06       56.41°       57.09°
    4       4.000e+03    1.027e-06    2.608e-07      164.55°      165.23°
    5       5.000e+03    1.262e-06    3.207e-07     -177.53°     -176.85°
    6       6.000e+03    1.038e-06    2.637e-07      179.93°      180.61°
    7       7.000e+03    8.854e-07    2.249e-07      179.88°      180.56°
    8       8.000e+03    7.748e-07    1.968e-07      179.92°      180.60°
    9       9.000e+03    6.887e-07    1.749e-07      179.93°      180.61°
   10       1.000e+04    6.198e-07    1.574e-07      179.94°      180.62°
   11       1.100e+04    5.635e-07    1.431e-07      179.94°      180.63°
   12       1.200e+04    5.165e-07    1.312e-07      179.95°      180.63°
   13       1.300e+04    4.768e-07    1.211e-07      179.95°      180.63°
   14       1.400e+04    4.427e-07    1.125e-07      179.95°      180.64°
   15       1.500e+04    4.132e-07    1.050e-07      179.96°      180.64°
Total Harmonic Distortion: 0.003912%(0.004251%)
And here is FFT for 28Vpp into 8ohms (12.5w):
attachment.php
And here are the distortion components for 0.016% THD:
Code:
    1       1.000e+03    1.417e+01    1.000e+00       -0.68°        0.00°
    2       2.000e+03    2.278e-03    1.608e-04     -115.76°     -115.08°
    3       3.000e+03    5.799e-04    4.092e-05       51.25°       51.93°
    4       4.000e+03    1.615e-04    1.139e-05       20.66°       21.34°
    5       5.000e+03    6.764e-05    4.773e-06     -110.87°     -110.19°
    6       6.000e+03    2.623e-05    1.851e-06     -177.51°     -176.82°
    7       7.000e+03    8.719e-06    6.152e-07       98.94°       99.62°
    8       8.000e+03    3.366e-07    2.375e-08      -37.39°      -36.70°
    9       9.000e+03    2.908e-06    2.052e-07     -157.53°     -156.85°
   10       1.000e+04    2.602e-06    1.836e-07      178.74°      179.43°
   11       1.100e+04    1.990e-06    1.404e-07      176.05°      176.73°
   12       1.200e+04    1.803e-06    1.272e-07     -179.77°     -179.08°
   13       1.300e+04    1.709e-06    1.206e-07     -179.55°     -178.87°
   14       1.400e+04    1.588e-06    1.121e-07      179.91°      180.60°
   15       1.500e+04    1.477e-06    1.042e-07      179.90°      180.58°
Total Harmonic Distortion: 0.016635%(0.016717%)
Looks like fun!
Question - what about using JFETs for LTP?
Also - is there a way to get more power? Say 100W?
Maybe you could run a pair in balanced configuration for 80 watts, but would be kind of a waste. I ran a pair of F4 stereo amps that way, great way to heat a room but you just don’t listen to 80 watts continuously. The extra watts are good for headroom and a class d or ab is far more practical.
Bill
Besides the points that wirewiggler brought up, also bear in mind that doing a balanced bridged configuration will cancel 2nd harmonic distortion, and this amplifier design was specifically tuned for a certain harmonic structure profile (see 1st page of this thread); at which point, it’s not an Alpha Nirvana anymore. Hugh Dean has written about his philosophy with regards to the harmonic profile.
Best,
Anand.
Anand,
Funny you mentioned that, I have been enjoyed my F4 running single ended with a ASKA Lender preamp driving it. Mr Pass had mentioned current buffers amps sounding better on full range speakers. The combo driving my little Fugal Horns in my office sound glorious.
Bill
Gee, those Modushop 5RU, 350mm deep cases (single heatsink each side) that I bought for my AN 4Rs, certainly work well as total heatsinks! 🙂
Winter has arrived so I have put my ANs back in the system ... after most of the day turned on, panel temps (outside) are as follows:
* heatsinks (not the fins thereof) in the middle of the bolts holding the output devices - 72 deg C
* front panel, centre - 48 deg
* back panel, centre - 47 deg
* top panel, centre - 47 deg.
Throw a couple Noctua quiet fans on there it will run cool you would be fine.
Scott
Haha - nooo ... that would be going backwards, Scott. 🙁
My first build of these amps used a 3RU Modushop case, with a CPU cooler for each pair of output devices - each set of cooler fins having an 80mm supposedly-quiet, Noctua fan. This "worked" very well - in the sense that the heatsink temperature (from memory) was about 60 deg C - but even though I had slowed the fans by reducing their voltage, I didn't like hearing the noise of 4 fans. So I rebuilt the amps using 5RU Modushop 'Dissipante' cases, having a 300mm long heatsink, each side.
@Anand - yes, mine are the 4 ohm version. +/-22v DC rails, 3a bias.
Andy
Hi Vunce,
Not quite - I have a pair of stereo AN4Rs ... so 4 channels of amplification.
So each 300mm long x 200mm high heatsink is taking care of 3a x 44v = 130w, right?
Andy,
I’m curious since you built a 4 ohm version yes? What are your voltage rails and bias current on the output stage?
I think your Modushop 5U/300 has a dissipation of 0.18 degC/watt. Given Modushop’s reputation, I bet this is a conservative rating.
Best,
Anand.
And Anand ... if you think that my 72 deg heatsink temp is a problem - it would be possible to re-house the ANs a second time, by putting them into the 400mm deep Dissipante cases. This would give each output device its own 200x200 heatsink ... instead of them sharing the one 300x200 heatsink.
Or even 500mm deep! Here, each output device would have a 250x200 heatsink.
Do you think this would make a worthwhile difference to the heatsink temperature? (These are my "forever amps", after all! 🙂 )
