Alpha Nirvana 39w 8ohm Class A Amp
An amplifier’s ability to handle dynamics
from what I hear, it’s very dynamic with gobs of cone slapping bass.
Much like a powerful Class AB in grunt and even the way it plays rock music.
It’s unlike any SE Class A I have heard before - which I would say tends to be more “polite”. 🙂
X made a very interesting observation about class A/ amplifier dynamics
As it was triggered by the sound of the SySuLu, I thought it more appropriate to reply in that thread. If you are interested in amplifier dynamics, you might find it interesting … 😉
https://www.diyaudio.com/forums/pass-labs/373533-susylu-12.html#post6795217
A very clever PP A Class
It is well biased and the constant current is a neat idea but, it does seem to run in Push Pull mode, and therefore not strictly SECA design.
A Neat idea.
I saw something similar in the early 1970, one done by Sir Clive Sinclair and a version by Linsey Hood,
The Mr Hood one was published in WW or PE.
Yes, PP Class A
Daanve, it is indeed push pull, but Class A of course because neither device turns off.
X can be given credit for the clever Hawksford Cascode which maintains constant voltage across the LU power jfet, and setting the bias with ground potential on the gate relies on depletion biasing of jfets, using the DCR of the dual inductor to achieve the 3A quiescent.
It really is a new version of an old idea and proposed on this forum with Susan Parker a long time ago. She did a beautiful amplfier with an absurd low parts count.
HD
Susan Parker - Patrick Turner
And don't forget the late Aussie Patrick Turner:
Let’s move further discussion of the SuSyLu amp to its proper thread and keep this one for Alpha Nirvana.
Good idea, X. (But I think it was you who introduced the SuSyLu amp to this thread?)
Absent the anti-thump turn-off option of the SSR Speaker Protection board, does the AN amp typically generate a turn-off thump?
I presume you mean "without the SSR Speaker Protection boards, does the AN amp generate a turn-off thump"?
If so, I can assure you ... it doesn't. 🙂 (I had to remove my SSR boards when I had to re-organise the layout of my AN 4Rs, to fix the instability problem I was experiencing. There was simply no room for them. 🙁 )
Andy
Hi fellas,
I’m gearing up for my next build, and I have a few questions.
Since my supply is set in stone at +/- 24Vdc (ie I can’t do +/- 28Vdc), can I increase the bias a bit? Higher than 1.65A by changing the source resistors from 0.22R BPR to 0.18R BPR (assuming FQA transistors)? My heatsink is a 5U/400, comfortable with 90W dissipation.
For the feedback capacitor, C124, can I use a 330uf/25V cap that I have here in my shop instead of 470uf ?
Best,
Anand.
PF4Ever,
Yes, I was just making sure I wasn’t going to make the design unstable. I’ll likely get both 0.22R and 0.18R resistors and experiment. I have a 5U/400 test mule heatsink and bench supply for exactly this purpose. My speakers aren’t difficult loads per se given how loud they get on the Aleph J and Aleph J Zen. And I don’t think the power differences between them and this AN Nirvana will be an audible difference for me given that my speakers are 96 dB sensitive with an impedance nadir of 4.8 ohms over the narrow range of 100-200Hz.
But I do think the dramatically lower overall THD with decent harmonic spectra and low output impedance/high damping factor will be audible.
It’s important to keep perspective with all of this and realize music is dynamic and changing.
Thanks Hugh for the confirmations.
Best,
Anand.
Not yet........!!
Hi Studley,
Not at this point, but from where I sit, a city with temperatures up to 45C in summer and rising with each decade, and some of the most expensive electricity in the world, I'm somewhat discouraged.
I have always found that Class A is a brute force technique to ensure outputs never switch. I have found over decades in this insane field that Class AB is the greatest intellectual challenge and a good AB is difficult to best; but then, I'm an old geezer and the future is probably Class D, like my TV and car entertainment amp.
HD
OK thanks Hugh. You need to come and live in the North of England 😉. I couldn’t live with the temperatures in Oz, I don’t even want to visit for that reason.
I own a superb Class AB amp (Neurochrome) but IMHO a good Class A amp does something special that no Class AB I’ve heard can replicate.
