Right. And for practical purposes, the majority of modelling software round things off slightly; under those conditions, there is basically no difference worthy of the name. I've just had a very quick gander & under identical box conditions, a sealed Butterworth has less than 0.1 litre and about 1Hz difference in Fb; you'd get about that much variation from a change in climatic conditions, and if you can hear that, you're doing better than I am. 😉
Haha, thanks Scott and Dave for the explanation. This is reassuring! I have removed the stuffing (stuffing was included in the CM5) which helped a bit. I knew slamming the driver in the only bookshelf enclosure I had available would most likely not be a perfect fit. Lower and midbass is still off by ear. I will have to set up my measuring gear to confirm what I am hearing.
I will refrain from reviewing the driver until it has a proper and suitable enclosure, which they deserve, but I am really excited still. There is a lot just right wrt. The highs, voices and spatial detail.
So, would these fit the Water Buffalo's or Sea Stack MLTL's?
Thanks,
Robin
Thanks,
Robin
I found that my A driver needs a box of 12.1 liters. Driver B needs a box of 11.66 liters. 0.44 liters difference.
Is that good ? Difference of 3.8%
Madison:
"After construction, each driver is individually measured in the anechoic chamber at the Markaudio factory and pair matched based on that data to within, 0.5% tolerance."
Madison:
Scott.
Do you think Nostromo Medium 0v82 will work with 10MAOP?
11 l in volume.
Or Nostromo Large 0v82 16 l in volume?
Is it a good outcome to start with?
I was so happy with Nostromo Large 0v82 16 l with Alpair 11MS.
11 l in volume.
Madison:
Madisound 😉
To Fs, which is the tolerance criteria.
Variation in boxes is beyond the remit of a driver manufacturer: that falls into the 'up to the builder' category, since any differences vary with box type and alignment.
Today I shorted the ports to the length that modeled well in WINISD (5 cm shorter 😛). I also removed the stuffing. The lower bass cleaned up and midbass has more presence now. I am very happy with the result from such small cabinets.
I admit that this is my first exploration of full range drivers and must say they have a lot going for them. It gives a satisfying listening experience unlike many other bookshelves I tried.
So far I am positively surprised what value they are to me.
The lovely thing about DIY is that I can start my search for proper enclosures while enjoying the sound as is along the way!
I've been thinking a lot about the mini onken.
Should you always tune the box according to the Golden Ratio? Should you use Fo in the driver?
Is it optimal to use 6 ports? Saw that it was used 1 or 2 in previous fonken models.
Regards Leif
Regards Leif
In order:
- Golden Ratio is just a set of proportions applied to a given volume. It isn't a box alignment or tuning frequency.
- They are normally tuned according to the alignment Dave is targeting (remember, these are largely 'his' box type -while others have used variations in the past, in recent years, he's been the one has worked with it the most). The response is not always accurately shown in lumped-element modelling software either -not without some background knowledge of the physics / history involved, & sufficient measurements to adjust the data input to approximate the load behaviour.
- No, you 'just' use the number that will provide the desired total vent CSA, aspect ratio and bracing to the side-panels.
I'm looking at the Alpair 10 Mar-Ken10 1v01 drawings.
Interesting to look at how it is matched with the driver. 6 ports. Similar to a lot of what's out there from Dave.
Why is there a partition wall inside the box? Target volume is 14 litre. I need only 11-12 litre.
Maybe this box would fit MAOP10.2?
The partition wall you mention is called a brace. It's there to increase the structural strength, gently couple the back of the driver to the enclosure, and raise the panel resonant frequency (and Q) to reduce the chance of it being excited and cause audible colouration.
When modeling a miniOnken you need to do an additional mental step not shown by the modeler to estimate the LF extention (anechoic). The alignment is a shape i am looking for. It takes into account the loses in the high R vents. I am not going to give it away, i have given many clues thou.
6 vents is purely aesthetic. Most have 6, some have 8, but 10 more likely (a prime nuber down each side). In some of the less complex varitions you will find 1 or 2 vents.
dave
dave
I do move th edriver on the baffle so that its centre line aligns with either teh centre or ends of a slot.
dave
Tuning of a miniOnken is very driver specific, whilei reuse the boxes all the time, the venting changes depending on the driver in the box. Much more so than the box-dominant horns & TLs comeing from Scott. But teh R in the vents decreases the impact on the response of dynamic changes in the T/S parameters.
dave
dave
I have looked a bit at the ports for MAOP10.
Can 2 ports with 1.5x7cm and a length of 20cm work in a 11 liter box?
Good!
Tell me when you are done. Really want to try your drawing on a mini onken.
Get in touch when you are finish.
Regards Leif
Regards Leif
- Full Range
- Alpair MAOP 10.2
