Aleph J illustrated build guide
Aleph J and F6
i recently bought a set of Aleph J boards from th store and changed my spare F5 to Aleph j in less than a day's effort. Following 6L6 I build instructions took me less than few hours to setup the amp and start listening.
I had built earlier a Aleph J using Peter Daniel's boards but did not have good quality components. This time ordered the entire BOM from Mouser and built using prime parts. The amps sounds excellent and has terrific bass extension in addition to strong dynamics. Will add the pictures of the build shortly.
One observation FWIW is that I disconnected a Semi South based F6 from the chain and connected the AJ. What I noticed as stark difference between the F6 and Aleph J is that F6 has much better resolution compared to AJ, while AJ has better low end extension. Did other forum members notice a similar difference?
Thanks 6L6 for this build guide.
Tonight, I made the first test of the PSU and I have a question (maybe it has been asked before, but it's hard to search in such a long thread): I measured +25.7V and -25.7V on each rails, is this voltage OK?
(I use use a 2*18V Amplimo transformer and a DIYaudio Universal PSU)
