Aksa Lender P-MOS Hybrid Aleph (ALPHA) Amplifier
Joined 2014
The BB build has started......
netweight 429g
GAMMAXX 300 DEEPCOOL- CPU Air Coolers
Fan Speed 900±150~1600±10%RPM
Max. Air Flow 55.50CFM
Noise 17.8~21dB(A)
Reported on B.B Alufins 28C VS heatpipe 38C on 10%Rpm
Deepcool S40
Net Weight 610g
specs 17.8~26.1dB(A)
noisy compered to the almighty deepcool 300
Net Weight more on 181g on deepcool s40
DEEPCOOL GAMMAX S40 CPU Cooler Review
temp over ambient temp 24.5-25°C
Mpemba effect?
Maxwell demons?
atmosphere pressure?
Ranque-Hilsch vortex tube?:confused:
Joined 2014
Tonza,
Thanks for the cpu cooler links. I missed the fantastic price on the
Gammaxx 300 so I went for the S40 since it had four 6mm diameter pipes and the same price as the 300.
JPS64,
For some strange reason even the Aavid Thermalloy - os520-100-b is not obtainable in the USA? Maybe my search skills are diminishing :)
That’s really weird :(
Can I use a 0-22v 6.8A x2 (dual secondary) toroidal for the Alpha 20W board? Is the voltage more and if its the case can I use a higher wattage and low resistor on the CRC psu board to achieve the required voltage. I have this in spare which I can use and if not this I need to use my other spare 0-18v 7A x2.
