Ups but it is shipped as well
Sent from my iPhone using Tapatalk
Hi Sonny,
The DAC reach my home... Thanks!
I hope to have the time to try it during the week-end.
Best Regards,
Enrico
Hi Sonny
I rigged the DAC up on the bench to watch the currents. Positive 15 seems to take a lot more then -15 in idle. Is this normal values? (It is 15 on the right PSU also, the 1 is hidden on the pic)
Ok thanks. So that is what its going to draw in use, 14/43 mA or what shall I aim for. I think you said like +/-200 mA somewhere?
The discrete output stage draws A lot more... Close to 140mA extra
Aha ok thanks. Will start up with this and see how I like it first. Gonna feed a DCB1 via Muses 72320.
burninggecko - 1x Chassis, 1x LPS, 1x XLR, 1x RCA
Nikola Krivorov - 1x Chassis,1x LPS, 1x XLR, 1x RCA
Vitalica - 1x Chassis, 1x LPS, 1x XLR, 1x RCA
Sebbyp - 1x Chassis 1x LPS 1xXLR
I have ordered the Frontpanel and buttons at a new CNC shop. The old place told me that they needed 6 weeks more.
So thats why i have spoken with a new place today.
BR
Sonny
BR
Sonny
Unfortunately I have to back off from my order, in fact I will be forced to sell my set of preamp and DAC with discrete stage so if anyone is interested please let me know. Apologies Sonny, it was not what I expected 🙁
Maybe anybody tried LME49990 instead of analog devices ADA4898, ADA4627?
Can you write down some words about differences in sound.
Thank you very much.
D
D
No problem
Ok. We have received rca connectors this week. So shortly it Will ship.
Sonny, I was trying to upgrade the LCD firmware but I've run into a problem.
I'm using SAM BA 2.16 because it's what is available on Atmel's page.
I'm able to connect and erase the application memory but I'm unable to write the new firmware.
The error message is "Writing to the monitor area is forbidden, write operation aborted"
I've set the address to 0x02000 as shown in your guide.
I'm trying to write Mirand Frontpanel 271215.bin
Any ideas on what is wrong?
Hi Sonny, there's also another issue I'm seeing with the DAC firmware.
With 261215 and 271215, in ASIO mode, it takes about 3 seconds for the DAC to change sampling frequency when a song with a different sampling frequency from the previous song is played.
In Foobar2k, it results in the following messages after about 3 seconds once a song with a different sampling rate is played before the song plays normally.
Unrecoverable playback error: Could not set sample rate to 44100 Hz
Unrecoverable playback error: Could not set sample rate to 96000 Hz
Unrecoverable playback error: Could not set sample rate to 192000 Hz
This does not happen in the 271115 firmware. I switched back to the older firmware and the issue I had with the newer firmware is gone.
- Vendor's Bazaar
- AK4490 USB Dac with dsd support.
