Does Horn Response allow you to simulate that with these ATH waveguides? Or is there a standard horn shape that is close enough to an ATH waveguide for simulation?The frequency response of the midrange is a tradeoff between how deep in the horn the holes are (loading by the horn) and how big the chamber/port size and length are.
It's basically a miniature 4-th order bandpass subwoofer design
I think the better way to do it is to model the driver and port (bandpass) as a lumped element coupled to a driver element the size of the port like shown in this post. This roughly equivalent to what Horesp can do except directly in ABEC with the exact shape created in Ath.Does Horn Response allow you to simulate that with these ATH waveguides? Or is there a standard horn shape that is close enough to an ATH waveguide for simulation?
https://www.diyaudio.com/community/...bandpass-mid-in-unity-horn.88237/post-4152484
You can see in the output graph the bandpass peak and cancellation notch in the output on the blue trace.
That can be done with an Ath horn model with a little bit of CAD work and some ABEC understanding, or maybe this is another thing that mabat wants to automate to remove that barrier to entry?
Sometimes, rest refreshes and inspires more than anything else.I've been occupied with something else lately and it seems I can keep only one thing in my head at a time to do it properly - getting old I guess. I need a break
Merry Christmas Everyone!
R-OSSE Waveguide rev.6 with a ST260 redefinition: https://at-horns.eu/release/R-OSSE Waveguide rev6.pdf
Merry Christmas! 🎄R-OSSE Waveguide rev.6 with a ST260 redefinition: https://at-horns.eu/release/R-OSSE Waveguide rev6.pdf
I've been able to more or less figure out horns with circular throat, but have some issues with the "Horn.Adapter" command trying to get a rectangular throat with this mouth profile.
Code:
;--Horn Throat and Coverage---
Horn Geometry = 2
Length = 100
Horn.Adapter = {
Width = 28 ; [mm]
Height = 50 ; [mm]
Segments = 1
;---Mouth Terminating Flare---
Term.s = 0.7
Term.n = 4.0
Term.q = 0.996
;-------Horn Morphing---------
Morph.TargetShape = 0 ; 0 = no morphing (the default)
;-------Mouth Profile---------
GCurve.Type = 2 ; superformula
GCurve.SF = 1.6,1,4,6.93,4.8,4.9 ; values of a,b,m,n1,n2,n3
GCurve.Width = 155 ; width on x-axis for Desmos profile[mm]
GCurve.Dist = 0.5 ; half the length
;---Model Mesh Resolution-----
Mesh.AngularSegments = 120
Mesh.LengthSegments = 20
Mesh.ThroatResolution = 4.0 ; [mm]
Mesh.InterfaceResolution = 8.0 ; [mm]
Mesh.InterfaceOffset = 5.0 ; [mm]
;--ABEC Analysis Parameters---
ABEC.SimType = 1 ; 1 = infinite baffle
ABEC.f1 = 800 ; [Hz]
ABEC.f2 = 20000 ; [Hz]
ABEC.NumFrequencies = 40
ABEC.MeshFrequency = 25000 ; [Hz]
;-ABEC Observation Parameters-
ABEC.Polars.Distance = 2.5 ; [m]
ABEC.Polars.Step = 7.5 ; [deg]
ABEC.Polars.Points = 8
ABEC.Polars.Horizontal = yes
ABEC.Polars.Vertical = yes
ABEC.Polars.Diagonal = yes
ABEC.Polars.DiagonalInclination = 0.0
;-----Output Parameters-------
Output.STL = 1
Output.ABECProject = 1
Just playing around with the array possibilities. I understand how to assign different weights/delays in observation.txt to individual driver groups. However: where/how could I add individual filters to driver groups? In Akabak easy for me but Abec scripting is still a challenge sometimes
In a Lumped Element Scriptwhere/how could I add individual filters to driver groups?
o.k.
but why so complicate, it is nesessary?
my idea, combine
http://www.pispeakers.com/catalog/product_info.php?products_id=104&osCsid=dfejvb4qbm5ana63se7m8fk055
with
https://peaveycommercialaudio.com/w...atic-Throat-Waveguide-by-Charles-E-Hughes.pdf
you know, what I mean,
use a conical horn with adapting the tweeter like Hughes
and you have plane walls for the midrange
anotheridea,
it is usefull to use Tectonics BMR for Midrange, because the membran is flat?
Yet another update, summing up much of what has been found about (free standing) waveguides in this thread - not all of it.
http://www.at-horns.eu/release/R-OSSE Waveguide rev7.pdf
Hi fluid,
thanks for the hint. Looked around in the Abec examples....tons of variations but not directly what I need. Could you or someone please just give me a example of a 24db/oct LR high or lowpass for a driver group? I know is maybe a too simple issue for asking here but I struggle with it as in any example there are many other things implemented, too. So I cannot directly see what is the simple part I need.
Thank you!
Thank you!
Hi Marcel,BTW, I tried to simulate a throat extension plug (bridging over the driver's conical exit section) for FANE CD131, which is quite a nice 1" driver. It has a 3-slot phase plug ending at ⌀16 mm and 30° conical exit. Extending the waveguide profile down to the phase plug ending, these are the results for a ⌀320 x 120 mm free standing waveguide based on the latest advancements:
I'm trying to make version of ST260 with an insert plug that goes inside compression driver conical exist section but I haven't been able to come up with settings to achieve it with ATH. How do you make plug that has curvature to it, how to extend the R-OSSE profile all the way through the plug as well? Throat.ext parameters seem to always make a conical section to the profile. There is numerous references to this in the thread by you, perhaps its something that is not documented? Guiding curve? Thanks!
Added a mention of the "Throat expansion factor", page 15:
http://www.at-horns.eu/release/R-OSSE Waveguide rev7.pdf#page=15
Assuming you have a driver that makes it feasible, a good approach is to set a0=0 and increase k (the throat expansion factor) until the waveguide fits into the driver (you can do that because you start with a smaller throat). Sometimes it helps to add a small lenght of a straight extension but that's basically counter to what you are trying to achieve.How do you make plug that has curvature to it, how to extend the R-OSSE profile all the way through the plug as well?
- Acoustic Horn Design – The Easy Way (Ath4)
