Acoustic Horn Design – The Easy Way (Ath4)
The idea of doing a big waveguide in multiple pieces has got me tinkering with larger, free standing waveguides.
Here is one.
The config file is set to a beamwidth of 110 degrees, but I'm using a variable beamwidth that's based on angle. I do this to achieve the square-ish shape. I tried using a waveguide that was round, but the square-ish waveguide proved to be flatter. (I'm not sure what voodoo Mabat is using to get such flat response from a round symmetrical waveguide 🙂 )
Here's the log:
C:\Users\johnv\Downloads\Ath-4.7.1>ath.exe demos\aug13.cfg
Ath 4.7.1 beta4 32bit
Freeware version for personal non-commercial use
-destination directory: output\demos\aug13
-initializing
-fixed length: 127 mm
-calculating profiles
-max length after rollback: 119.214 mm
-writing ABEC project
-writing geo file bem_mesh.geo
-final mesh average throat angle: 15.000 deg
-reading source definition script
-adding rear side surface
-running 'C:\progra~1\gmsh\gmsh.exe bem_mesh.geo -'
Info : Running 'C:\progra~1\gmsh\gmsh.exe bem_mesh.geo -' [Gmsh 4.8.4, 1 node, max. 1 thread]
Info : Started on Fri Aug 13 00:37:41 2021
Info : Reading 'bem_mesh.geo'...
-setting mesh elements for radial drive
-running 'C:\progra~1\gmsh\gmsh.exe mesh.geo -'
Info : Running 'C:\progra~1\gmsh\gmsh.exe mesh.geo -' [Gmsh 4.8.4, 1 node, max. 1 thread]
Info : Started on Fri Aug 13 00:37:44 2021
Info : Reading 'mesh.geo'...
Done.
Final width x height = 404.8 x 404.8 mm (15.938 x 15.938")
Final length = 119.2 mm (4.693")
Here's the config file:
Throat.Profile = 1
Throat.Diameter = 34 ; [mm]
Throat.Angle = 15 ; [deg]
Coverage.Angle = 55.5 - 12*sin(p)^4 - 12*cos(p)^4
Length = 127 ; [mm]
Term.s = 0.95
;Term.n = 1.0 + 1.0*sin(p)^4
Term.n = 4.0
Term.q = 0.996
Rollback = 1
Rollback.StartAt = 0.6
Rollback.Angle = 135
Source.Contours = {
zoff -2
point p1 4.68 0 2
point p2 0 14 0.5
point p3 1 15 0.5
point p4 0 16 0.5
point p5 0 17 1
cpoint c1 -18.59 0
cpoint c2 0 15
arc p1 c1 p2 1.0
arc p2 c2 p3 0.75
arc p3 c2 p4 0.25
line p4 p5 0
line p5 WG0 0
Morph.TargetShape = 0
Mesh.AngularSegments = 64
Mesh.LengthSegments = 20
Mesh.ThroatResolution = 4.0 ; [mm]
Mesh.InterfaceResolution = 16.0 ; [mm]
Mesh.InterfaceOffset = 22.0 ; [mm]
ABEC.SimType = 2
ABEC.f1 = 500 ; [Hz]
ABEC.f2 = 16000 ; [Hz]
ABEC.NumFrequencies = 61
ABEC.MeshFrequency = 1000 ; [Hz]
ABEC.Polars:SPL = {
MapAngleRange = 0,90,11
;NormAngle = 10 ; [deg]
Distance = 2 ; [m]
Output.SubDir = "demos"
Output.STL = 1
Output.ABECProject = 1
There's been a lenghty discussion about what DI is the most suitable for the current state of the reproduction industry. I think the following might be an alternative to the almost flat DI as in the CE series.
CE360N (1" throat, ⌀362 x 118 mm, work in progress) -
(Maybe this is already too much of a rise, I really don't know. Would love to hear both and compare directly, which may actually happen in a near future.)
TNT, Kimmosto demonstrated earlier this year that smoother power response can be achieved with cc ~1.4 wl, and worst case is about .5-.7 if i remember, this removes need to push the waveguide over the woofer unless you can drop down the xo enough to achieve near 1/4 wl c-c with the ath waveguide. Less diffraction problems at least.
Good then I can go back to the original...
attachment.php
  • 2_5way-WG360b.mp4
    1.8 MB
The axisymmetric case is quite extreme, it won't be nearly as bad in a rectangular box IMHO, but nevertheless.
Three scenarios:
0 = no waveguide
1 = flush mouth (no lip)
2 = rolled-back lip
The outer dimensions are always the same (⌀400 mm), WG is ⌀260 mm at its outer edge.
First, driven the midrange (red) area -
Here are all the raw protocols images for easier comparisons.
One thing is clear, I think - it's not the best idea to place a waveguide intended as free standing "flush mount" into a baffle. It's still better to use a flat edge WG in that case. And then round the edges of the enclosure heavily.
The second takeaway for me is that up to about 800 Hz it doesn't make any difference in this case (the wavelength is so long that it just doesn't matter).
