AB100 Class AB Power Amplifier
hello
i only matched the input transistors but can't tell how much it affects the dc offet - in my case it's approx. 10mV in both channels.
I use other output transistors (MJ11015/16) and they are from the factory at quite the same range judging by the bias voltage drop on individual emitter resistors.
but i don't know what is the parameter distribution of TIP series transistors in this regard.
Amp ha been completed and it sings like crazy :D
Everything worked even without test boards. No hum, dc offset 2mV and 10mV per channel.
Bias 40mA per transistor - runs cool.
no turn on/off thumps.
PSU - +- 45V 30 000Uf in each rail.
indicator diode foe each rail.
Transistors - ztx450,550,MJ340/350, mj11016/15.
0,5 ohm emitter resistors and base stopper divided-100R on PCB and 100 on transistor base pin.
I will measure later with scope and sound-card - now I am a little tired after amp hobby work :rolleyes:
nice front panel, " angry villagers armed with pitchforks and torches" as mentioned by NP in first post. just had a look at your work. congrats!
Got a chance to finish the boards. I have installed just 1 pair of OP transistors for testing. Running on +-40VDC. Bias is set to 20mA, DC offset on boards is 9-12mV and 15-18mV. I have just HFE matched the input transistors. Square wave looks good, 1kHz and 20kHz. I have used all die original resistor values except R3 is 1K.Sound is good, high frequencies are more subtle, sounds like more H2. I think I need a little more gain, maybe change R3 to 470R. I will first test with a decent preamp and not using a phone as source. What will the advantage be in changing the emittor resistors from 1R to 0.47R ? Thank you Mr Pass and Osscar for the help and thanks Prasi for the great pcb layout !:)
HI,
Looks very good, no ringing etc. Yes , you can adjust gain. According to D.SELF's book - the smaller Re - the better, but you need a greater bias current and a greater risk of burning something :nod: usually i see that all amplifiers use 0.22R or 0.33R or 0.47R.
Regarding FFT - according to LT spice - with TIPs you have more 3H, but with MJ - more 2H..i cant explain this - i don't know how accurate are the different transistor models..best way would be to measure but my EMU usb card doesn't work with win 10...so i need to buy a newer one - Focusrite for example.
not so much output power - but more each output transistor bias - with 1R N.Pass has specified approx. 20mA per transistor.
With one pair and 0.235R I set 100mA per transistor and with 2 pairs and 0.5R - 50mA on each. with these settings amps run cool and sounds nice.
Well I have tested both boards today for an hour or two on idling with input shorted. 9-11mV dc offset, bias very stable at 20mV. It might be that the caps have reformed a bit but the sound is great, I'm sticking with 1R emittor resistors for now, can always change if needed. I might use another transformer with +-50V rails, but I dont think it is necessary. A very happy chappy I am.:D
