900W H-class PA Amp with Limiter
The attachments from moore4889 could not be seen, but if you can picture it at 1khz it would be great.Greetings,
IMG_20191014_133052
class_td
I have completed TD 1800 as per schematic , but having problems, which along with marked photos I am posting. please Mr. Miles Guide
Positive side high voltage dropping too much, Amplifier section is similar to your h-900 but I can see changes, which I have marked.Also am confused as in some photos, positive side 5 watts resistor is of 10 k ohm , whilst in schematic it is 2.2 k ohm, Also capacitors in schematic are 3.3 uf and 10 uf. whilst in photo all 4 capacitors are 3.3uf. which also I have marked, I was able to switch on audio with 18-0-18 volt d.c., but biasing milli volt is too high 570 milli volt base to emmiter output transistor. please guide.
which coil T-157 ?
how many turns ?
do you have
Greetings Mr.Nmos,
As one can see from the photos I have posted I used Stacked blue cores and 28 turns to obtain 100uh.
