look PIC ?
how do you generate 18 V ?
separete PSU or from 140 V VCC / VSS with Resistor and Zener ?
i use seperate 18 0 18 vac trnaformer..as seen at the bottom..
i used 2 core just for test ...it reads 10uh...
Stewin, also puts an oscillogram at the frequency of 1khz.Thanks.
hi dorel ,it was not my work but the expertise of m.r moore4889
The attachments from moore4889 could not be seen, but if you can picture it at 1khz it would be great.Greetings,
thanks for the simulations and photos but please post bigger pictures
thanking you in advance steven.
Hi moore
Great, but do you know switching frequency from TD Rails `?
apex talk about something 50 khz,
can you check whats switching frequency from your TD Rail ?
regards
Nice work, dont forget wire jumper.
what is the red colred wire here dude
I have completed TD 1800 as per schematic , but having problems, which along with marked photos I am posting. please Mr. Miles Guide
Positive side high voltage dropping too much, Amplifier section is similar to your h-900 but I can see changes, which I have marked.Also am confused as in some photos, positive side 5 watts resistor is of 10 k ohm , whilst in schematic it is 2.2 k ohm, Also capacitors in schematic are 3.3 uf and 10 uf. whilst in photo all 4 capacitors are 3.3uf. which also I have marked, I was able to switch on audio with 18-0-18 volt d.c., but biasing milli volt is too high 570 milli volt base to emmiter output transistor. please guide.
68359007_1482533771889218_437424388824891392_n - Copy.jpg351.7 KB · Views: 279
please give me black layout of the board sir, thanks a lot
which coil T-157 ?
how many turns ?
do you have
- 900W H-class PA Amp with Limiter
