ye ápex its a idea but all the tehnlogie has been created by ideas ,and this huge amplifier should work, who could made the PCB of this low power amplifier Project 117 ![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Poštovani g.Mile, dali možete reći kolika je snaga r.m.s na 8ohm pojačala BA2000 i dali je to najjača verzija vašeg pojačala?
Pozdrav Zoran
![cop :cop: :cop:](https://files.diyaudio.com/forums/images/smilies/cop.gif)
English please.
Dear G.MI , if you can tell how much power rms at 8ohm amplifier BA2000 and whether it is the most powerful version of your amp ?
Hi Zoran
Pozdrav Zoran
English please.
Hi Zoran
Pozdrav Zoran
English please.
Hi Zoran
1000W/8R, VERTEX is my most powerful amp,
Which is true sir mile according to your suggestions. between the direction of the diode schematic and layout protect that I circled in red color?
protect H900
Schematic is corect, diode polarity is wrong (reverted) on pcb.Which is true sir mile according to your suggestions. between the direction of the diode schematic and layout protect that I circled in red color?
Litle modification again.... not conecting yet.... perhaps tomorow.
REGADS
Nice work,
accepted the love sir mile on your fast reply ..
regards
Amp based on B600
hi sir mile.pls check my schema sir if there something wrong.
coz can't continue my pcb if there's a mistake.
sir engel is this right or wrong?
can you make two separate board
output
driver
sir wil,
can I have this pcb,pdf file?
output
driver
how about the stepper sir?should i put it on the driver board or in the output?
- 900W H-class PA Amp with Limiter
