6V6 line preamp
6L6
Moderator
Joined 2010
This is from Ti Kan's site -
Will this schematic perform well? I sort of wanted to start with simple circuits rather than the regulator of heaters and a CCS. I'm not sure where this schematic was located.
The 5R4GY is overkill as a rectifier. It is rated for operation at 40,000 feet.
Is the finished amplifier going to fly on the outside of a commercial aircraft!!:eek:
5V4GA is a much better choice. But I guess you like many here in this thread need something to look at. Very strange design practice.:D
PS- I've built something like 50 amps for various purposes, never had to use a 5R4GY.:)
  • 5R4GY RCA.pdf
Thus Spake The Oracle!
Good for you, move to the front of the class!
What is your 'thing'? Congratulations if you got it to work.
In the real world your attitude is a formula for failure!:D
Oke,made a small change.
Wil put it on 7v to be save.
If one of the LED,s might fail.
