The problem with mechanical noise from the transformer solved.
the only problem that remain is big temp inside the box, on aluminium surface i can measure 44-48 Celsius degrees , temp air about 30 Celsius degrees.
Could you space the top plate 5mm or so above the wood frame? You'd get good airflow all around the perimeter.
@Nikososkey. Could you provide a little more info on how you built your heater regulators and HV regulators? I love how you used the brackets to make use of the allowable space.
My heaters regulators based on Salas L-Adapter
L-Adapter
GB for Salas L-Adapter Board
And the HV regulator it is the Salas reg
Simplistic Mosfet HV Shunt Regs
GB for Salas SSHV2 regulator
Some tests I ran a while ago. As the wavelength becomes shorter, red to green, the forward volts increase. Yellow & orange in between, Blue higher volts.
Yes? sow what?
Nice video*. So your build has L-Adapters for heaters on home made boards, also planning SSHV2 for B+. A BJT bias addition in the circuit. Why, you wanted to can scan for sweet spots?
*Weird I ordered a used cassette of the Synchronicity album by The Police just a few days ago featuring the original song from 1983.
Just heard the 6v6 preamp at the BAF 2019. I am building one.
Who presented it in Burning Amp?
- Tubes / Valves
- 6V6 line preamp
