How long can the leads be from the board to the mosfets?
For example, I will be using mono-blocks with 12" spacing between heat sinks.
From 6 inch center, if using a 4" PCB board on center, leaves approximately 4" distance to the power mosfets. The rule I remember was to keep the leads under 3 inches.
What's the best way to avoid issues and oscillation?
Thanks,
Vince
Thanks,
Vince
good to go
you can twist wires slightly , solder gate resistor ditto on gate
you can wrap it in heatshrink (wire , resistor and mosfet pin) , to ensure it mechanically
Digikey package arrived.
Still haven't purchased power supply caps but I now have everything I need to build a working prototype. I'll just use a lab power supply to start with.
Hopefully have something complete that plays music within 7 to 10 days.
I won't be able to make a start on it for a week.
Great Pico !
Please write us your feel & description about music with Schade50
Have a nice day 😀
Looking forward to your impressions on sound. 😀
Couple of notes.
1) With my batch of parts (10 pieces) I am getting values of Vgs between 4.85V and 4.95V for 3.2A (not 4.7V). Room temperature was at 15 C (Winter here), at higher room temperatures Vgs is likely to drop a little bit ( maybe 0.04V as a rough estimate).
Vgs adjustment between 4.65V and 5V would likely cover it for variations in parts coming off the manufacturing line.
2) For Id vs Vgs, I am getting similar values with IRFP250 (steeper than IRFP240 though) which isn't as dramatic as originally thought.
Still stable, but slow to reach equilibrium, somewhere between 30 minutes and 60 minutes from a cold start.I presume still stable .
This is just raw Id vs Vgs testing.
I'll start putting together the circuit
Hi Pico,....... but I am afraid It will be autumn since I start the BAF2025 amp.
Autumn of 2026?
or taking warp shots lately ?
(Generg is my man!)
well , who cares
nature of the beast
who is anal about that , servo is solution
Servo would certainly work. I like caveman circuits though. 😀
servo is neat , for tube rolling
Yeah that is cool. Hadn't thought of it like that.
I figure though, if you can bias (set dc offset) your Bablefish J up with 2A using IRFP150 with a simple trimpot where dc offset is critical, then this circuit with output cap should be reasonably straight forward.
Touch wood. Hahahahaha
there is (in Babelfish J and pretty much every second amp on planet) inherent servo (input LTP) which is taking care of output offset , via NFB
you don't have that in mumbojumbopuckamp
though, if Papa sez and shows it's doable , no reason for doubts
- 50w Single-Ended BAF2015 Schade Enabled
