500W PA amplifier with Limiter
andrewlebon,
but i think it's not right to feed pos.12v to pin 4,
and neg.12v to pin 8
hi engel dela pena
greetings yes its tested working on real 1000 watt speakers
1 tlo 72 step driver ic gets supply from 15 volt zeners on b500 pcb
2 i use IRF2807 MOSFETS GET WARM MY HEAT SINK IS THICK SO make heat
sink thicker
3 check amp with tlo72 step regulator with 100 WATT BULB IN SERIES
thanking you
andrew lebon
tlo
hi engel dela pena
sink thicker
thanking you
andrew lebon
andrewlebon
one last thing mate.
w/c of this two is your pin 1?
