i hope mile will confirm this before ill put the step drive in to my b500 thanx for the info
engel dela pena
engel dela pena
andrewlebon,
can you please post picture of working tlo step?
with dmm ac reading exeeding the first step supply
please,
i want to upgrade my b500,
i like class how it handle heat
please,
hi engel dela pena
greetings will post picture in 3 hrs as shops have not opened
need to buy camera batteries sorry for not posting pictures earlier busy exam
time here
thanking you
andrewlebon
time here
thanking you
andrewlebon
tekko,ur mixing up the pins, its mounted with pin 1 facing the connector.
evaluate the schematic if you follow the posted supply how can output pin1 go to bf422?
tl02
Please check pm ty
andrew have you test it did it work?hi engel dela pena
greetings mytlo 72 step driver
thanking you
andrew lebon
Please check pm ty
please show i.c. pin clearerhi engel dela pena
thanking you
andrew lebon
please clarify tlo72 pin supply.
thanks
hi engel dela pena
greetings yes its tested working on real 1000 watt speakers
1 tlo 72 step driver ic gets supply from 15 volt zeners on b500 pcb
2 i use IRF2807 MOSFETS GET WARM MY HEAT SINK IS THICK SO make heat
sink thicker
3 check amp with tlo72 step regulator with 100 WATT BULB IN SERIES
thanking you
andrew lebon
sink thicker
thanking you
andrew lebon
b500
what transformer u use?its hard to find -+90v.what speaker u use?thanks guys
the amp is working well
two days of testing no overheating
very good sounding amp
mamak,
b500 supply is 40-0-40ac
torroid,
i bought it from a surplus shop w/o coil,
and recoil it,
only using locally made speaker,but sound is clear amp is clean,many builder already testify
tlo
one last thing mate.
w/c of this two is your pin 1?
andrewlebonhi engel dela pena
sink thicker
thanking you
andrew lebon
i want to try build this amp and want drive pioneer car subwoofer.this amp enough to drive about 400watt amps?and my problem is build car smps.u have any circuit high power smps?mamak,
torroid,
and recoil it,
hi engel dela pena
greetings well -15 VOLTS NEGATIVE GOES TO PIN NO
1 PIN NO 8 GETS 15 VOLTS POSITIVE once u use step driver u really feel the power
thanking you
andrew lebon
thanking you
andrew lebon
thank you mate,hi engel dela pena
thanking you
andrew lebon
kindly attach here your answer to my previous post 915
- 500W PA amplifier with Limiter
