4000.1
Did everything, that you advised (filter inductors heated for 5-7 minutes with a 100 ° jet of air). There were no problems. The current consumption of 1.8 amperes did not change, clicks and wheezes in the speaker did not hear.
It's possible that the ICs were damaged during installation, initially. You can add windings to what you have to incrementally increase the supply voltage if you want to be cautious with it. Generally, if you don't see problems at this point (groups of outputs overheating, bad/weak drive signals...), things are OK. You may want to clamp everything down and let it idle for a while at the reduced voltage.
Installed the diodes. Everything became like in the post number 1. As I understand there is no frequency of self-oscillation. Can it be that it is not, because there is no audio input signal? But with +/- 12V power, self-oscillation was at 25kHz, without an input signal .. What would you advise?
Self-oscillation appeared when the amplifier was turned on with the speaker connected, without an audio input signal. I applied an audio signal to the input - there is a quiet sound. I'll fix everything on the radiators - I'll try to make it louder.
Добрый день. Столкнулся с такой же самой проблемой. Меандр исчезает если установить выходные транзисторы. Возможно этот усилитель каким то образом попал ко мне, либо такое со всеми 4000.1
Good evening. Faced with the problem of tornado 4000.1. The amplifier consists of 4 half bridges. Individually, each operates at a frequency of 100 kHz. 3 out of 4 are also launched, but not one does not work with one half bridge. If you include a pair of output constant -1.8V. if you turn on all 4 the output HO transistors explode in two half-bridges and LO in one. Already went through everything and replaced everything, but alas
