3a5 output stage advice
Speakers are 2 way based on audax drivers, amp is a LiFePO4 powered LM3875 amp that has seen off many contenders. The sound is very good, very dynamic, but smooth, and no harshness at all. A keeper.
More dynamic, and better (deeper) soundstage than before the coleman reg/filament bias/removing input cap.
when you are done with this and ready to move into 01a please let us know we will try to guide you through the build....remember it will not be easy. But if your amp and speakers are not at per the TT pre SQ may not be reflected properly.
I have an oddball 211 amp here, it was a 1980s UK cottage industry product that was very short lived, and has an odd design, I think it has a 12au7 into a 5687 and then the 211. Its been a long time since I pulled it out of storage. Sounded good but I think the design means it doesn't shine at its best. It had a habit of blowing the rectifiers on the heaters - and in truth thats another one that could do with a coleman reg!
The other valve amps I have are all push pull
I don't know if it really applies here, but the IDSS of the upper JFET in a cascade should be higher than the lower JFET (Horowitz and Hill). I don't know about options for the LSK170, but I'm sure others on then forum do.
Sheldon
I put together a simple CCS using a 10m45s supplying 4mA to the plate - this gave quite a jump in sound quality..... which of course has me wondering what a cascode one would sound like!
I'll get some bits together to try out.... the sound quality is pretty outstanding.
As always, thank you all for the help, it is much appreciated.
Felipe is right about Ale's Anode-Load - this is a very good implementation for horizontal load lines.
And with an anode current of 4mA, there is another reason to use it - it's difficult to build a cascoded depletion FET CCS that will work well at 4mA. It would need dissimilar FETs, with the lower part having an Idss much lower than the upper part.
Further explanation here:
Cascoded DN2540 CCS down to 0.3 mA
