I cut the angle I like using titebond wood glue for my builds so the angles need to be pretty spot on, unlike when using a urethane glue from a tube, which gives you more flexibility.
That being said, I forget what the angle was. When you initially cut off the board, leave that one longer so you can do the final angle cut on it after, without making the board too short.
Maybe I missed it, but how far up does the woofer get mounted on that board?
It's in the auto cad drawing in post #123. 209mm to the center of the driver I believe.
I drew it all up and measured the angle last night, seems to be around 3-4 degrees. Does that sound right?
That seems correct, it wasn't much of an angle on it at all. I just don't remember the exact number.
This build seems to go pretty fast. Only spent an hour on cuts and assembly so far, took me longer to draw it out and double check everything lol
Looking good! How many are you planning on making, and what kind of power (or what amp) are you using?
Edit: just looked back and you said you're planning on building two. I'd want a clean 1000w amp to power the pair....
yup 2 in the making. I have an EV Q66 to power them.
Electro-Voice Q66 900 W per channel power amplifier
is the reflector near the top where the handles is needed or just extra? I see the 3D rendering they used a reflector 45 degrees in the corner, but it looks like its to cover the built in handles on the enclosure?
thanks Oliver!
is that reflector piece more for the speaker? if so is there supposed to be another on the opposite side on the front wall?
Hi loudsubz,
The reflector would be to cover up the handle area. I don't think it is necessary acoustically, and I don't see a need for a reflector up front, but you can always try it to see if it makes a difference.
Regards,
Regards,
ok thanks. I wasn't sure if I was going to add a handle or not as I was going to build a dolly to move them around and worse comes to worse just add a small external handle that would screw in.
yes its just to cover the slotted handels,just another way to do it🙂is the reflector near the top where the handles is needed or just extra? I see the 3D rendering they used a reflector 45 degrees in the corner, but it looks like its to cover the built in handles on the enclosure?
got both cabs almost built, one just needs the last side panel on.
Quick questions:
1. I messed up on one of the openings for the driver, its a little big in some areas and when I lined it up on the face, I could see light in some areas where the bolt holes were. Should I just seal the ring with some caulking around the entire edge, or can I make a new ring out of 1/4" and put it between the cutout in the panel and the sub to assure a good fit, or will this cause issues since the driver is now 1/4" more away from the original mounting location?
2. When joining the last side panel on my build, one of the interior panels may have slipped a bit as I was standing on the panel to make sure I had a tight bond, but I felt the whole thing moving a bit. When I looked in through the speaker opening I saw the panel that goes straight up behind the woofer face, had come out slightly from the wood. I screwed it back down but am concerned other panels may be slightly loose that I can't see inside. Is there something I can pour inside the cabinet to seal up any cracks that may be there now?
Quick questions:
Things like that are why horns aren't really considers an "easy build"
That said, with each build they get better as you gain experience.
Honestly, if there is an air leak at the throat, it will become a huge issue. For something like this (the large hole, not enough wood for the screws to grab into and securely hold down the driver) it may be worth the $100 to start with new wood and start over. Also, panels must be air tight throughout the path length of the horn in order for it to work well.
Did you follow the construction technique that I linked to on the first post? I posted it to make the build go smoothly for others as well as share my experience (learning from my mistakes)
Hi loudsubz,
I second everything mRgSr says in #196.
As to your question in Post #195: "...can I make a new ring out of 1/4" and put it between the cutout in the panel and the sub to assure a good fit, or will this cause issues since the driver is now 1/4" more away from the original mounting location?..."
You could mount your driver to a 3/4" thick mounting ring with sunk in t-nuts from the back, and then glue the ring into the box, I don't think the acoustic performance would be hurt. You could also make up for the increased cross-sectional area at S2 by glueing 3/4" discs through the driver hole against board "G" (search for "cone correction"). The slight reduction @ S4 should not make any real difference.
But, you have a tested design, so I would recommend not to alter it any more than necessary.
Regards,
Regards,
I have followed the plans and also know from building multiple bfm cabs the proper way to assemble them, but that still doesn't make me weary when putting the last panel on. I will have to test it and see maybe its ok
Can
some more updates:
the one im a bit concerned about is the last hole. I had my buddy cut it out and I think he should have used a circle cutter as there is some flat spots on it. I may just make another 3/4" space out of wood and mount it on top of the hole and run my t nuts under it.
Ugh, that cutout is horrible. Was your buddy a bit tipsy when he did that? 🙂
It is very important that there be no leaks in that location in a TH as any that exist can make quite a bit of difference in the low frequency output. The spacer sounds like a good idea to me.
- Subwoofers
- $325 Lab 12 based PA tapped horn ~ 35Hz extension
