3 way definitive project — expert advice
I actually want to build something of my own that I will keep with satisfaction. But also to be able to play with. Monitor Audio are wonderful speakers, but the AMT tweeter and a 12 driver remain in the heart. I just bought a Xilica XP 4080. So now the fate is sealed 😅
Reactions: Juhazi
Forgive me, but unfortunately I am not technical enough to understand what you wrote. In this sense would you be willing to teach me by explaining it to me? Thanks.Anyway, my room is not dedicated to the system. It is a living room measuring 5x5 meters with a height of 3. The current speakers are at a distance of 2 meters and 20 more or less from each other, and about the same from the listening point. I do not have any acoustic treatment. However, I am looking for a speaker that returns more impact and dynamics especially from wind and string instruments. The current speakers are first series Platinum pl 200 audio monitors, purifi et400A pre topping pre 90 power amplifier, gustard X26III dac, and dedicated audio pc with all the attentions.
So I’d assume you plan on some measuring equipment to build your speaker…..you can use that gear to measure your rooms reverb….or reverberant time. You can plug this in to the formula Fs = 2000 * sqrt(T60 / V) to get your room’s Schroeder.
Your room doesn’t need to be dedicated to the system….that’s the major benefit of DIY….now your system can be dedicated to the room!….taking advantage of the limits of acoustics, placement and size limitations.
I typically advise first time DiYers that sub Schroeder or most often low bass frequencies are the foundation to success. This is the modal region and the easiest to mess up and has little to do with the speakers or subs……80% of the response comes from the room. Mess this up and your low end will always sound congested or worse. Now the midbass is off balance or lacks any definition…..every kick drum rings on…..every cello sounds like a cardboard box……these modal frequencies can literally destroy the presentation of a $10k speaker.
If you’re serious about your title….lets start here and forget the predetermined notions you have.
Some good threads to study, for dsp-active 3-ways, by member hifijim
Projects:
Tips:
Good basic info here too:
https://sound-au.com/articles/index.htm#cros
Some 3-way projects:
http://www.troelsgravesen.dk/Diy_Loudspeaker_Projects.htm
https://pkaudio.webnode.cz/21w-12mu-9800/
Reactions: Emanuele Del Piano
