No, that's just the Darwin Awards version of the story. In it, someone did this on the highway and crashed into a hillside. That is only a myth. In truth, that hillside was an abandoned mine shaft that the craft, which ran on rails crashed into and it collapsed, the guys sped off in their pickup, leaving skid marks that happened to point toward the rubble, makeing it look like someone was driving the rocket car on the highway and crashed into the hill and was killed. In truth no one was hurt or killed, but it looked like there was, and so the famous Darwin Awards story was born. See for yourself.
http://www.bored.com/rocketcar/
Anyway, enough of that, yeah, I agree with your statement "Whether Kilowatt builds this thing or not, it could be an interesting design to follow. I'm not sure why you folks are so upset he's considering this. We've cautioned him about the safety issue." But if people still think I'm doing something dangerous, they will often continue to warn me. Also, it's not all about the safety, some people think it's rediculous and pointless too. I might even be considering this possibility myself, but you still seem to think I'm stubborn as well as doomed. At least that's how it seems to me, maybe you think otherwise.
Anyway, if you have a huge area (I don't know for sure where this would be, but there are such places) that you want to fill with full, really loud hifi sound, what could be more cost effective than my design. It's much cheaper than even a bunch of Crowns, sounds way better, and power is always cheaper than speaker sensitivity. Maybe you're right though that I don't need quite 7200W, but I can always just use fewer 900W channels. Can anyone honestly think of a scenerio where my amp would be more dangerous than any other PA?
Some Realism.
Hi KIlo, multiple 900W amplifiers is a whole different thing to a single 7200W amp.
Indeed multiple amplifiers is the only correct way really.
Running multiple woofers in series parallel connection at high power is asking (begging ) for all kinds of damping/resonance related problems, however multiple amplifiers driving parallel loads is perfectly fine.
Indeed 12 woofers will give you all the SPL you could ever want - witness the big Genesis 1 system.
This has 12 carbon fibre 12" woofers and 4000W total between 16Hz and 120Hz.
I have spent a whole day with such a system, setting up and then listening, and that system is SERIOUSLY impressive.
Capable of causing structural damage if you were to resonate a room/structure with it, though.
Remember this would be for bass only, and if you want very high power full range system, it MUST be active crossover/multiple amp channels because passive crossover at 7200W is just not feasible.
Nobody is knocking you down, we are just trying to tell you the facts and it seems like you are not listening.
You have been told !.
Regards, Eric.
Regards, Eric.
Yeah, my plan has been to use 8 completely independent (except for chassis and highly reliable cooling system) 900W channels. 2 for bass, 4 for midrange, and 2 for trebble. I don't really see a difference between 8 amps and 8 amps in one chassis. One chassis was my originall plan, I don't see why I shouldn't do that. I will give each one their own supply with their own switches though for better reliability. I haven't ever thought of using a passive crossover, at least not since I've been on the forums, completely unfeasible, as you said. I once calculated the frequency/power curves that one would have, it was really bad, and the components would have to be huge and waste a lot of my precious power.
There would be 6 Eminence Delta 15" subs for each bass channel, 6 EV EVM10 10" midwoofers for each mid channel, and 6 horns (of unknown name brand) for each trebble channel. All the drivers would be horn loaded, and Xover frequencies would be 80Hz and 3,000Hz. But there are problems with series drivers? How severe? Is this just when you have like 3 or more in series (i.e. some of them are floating) or is it also when you have 2 in series. I wanted to use 3 in series, 2 in parallel. Any other way and I'd need a transformer in my power supply (wouldn't break too many of your hearts, just mine). What if the 3 are in the same box? Isn't there anything I can do for series drivers?
You know what would be really, really cool is if I could have an adjustable switching power supply for each amp that could go from +/-60 to +/-160V, but it would be way too hard to design and is almost unfeasible, unless some manufacturer already makes such a thing. It would give that isolation you're all so worried about, give me an excuse to make the high voltage amp, and allow me to run only one driver in series. The voltage could be raised for use with ESL's or if high transmission efficiency is needed (i.e. really, really long cables). What a compromise!
Sounds like you are at least considering your many options, which is good.
As far as PA systems are concerned- they always do it with multiple arrays of drivers AND amps. It is a much better way to go.
Here's my advice to you- take it as you wish:
build your 8-900 watt amps, with isolation transformers, but build them two at a time in your chassis. I think you will be impressed the first time you put 1800 watts to your subs!😀 I once rented a PA for my band for a medium-sized hall. It came in at 2000 watts total, and was really clean- plenty of headroom.
Why 12 ohms? I get the number, as it occurs often in dealing with speaker impedances, but you are making the solution more difficult than it has to be. To drive that kind of power into 12 ohms means your amp has to swing mega voltage, which will result in a compromised design (getting into slewing problems- adds so much circuit complexity to the front end). Remember- less is usually more, as far as devices in the signal path. In my opinion (of course) you would be much better off going into a 2 ohm load. I have also read that you really should never wire woofers in series. It dosen't make sense really, when you consider that you get nothing but power handling out of it. With a parallel connection, you get a 6db increase. Less voltage swing required, easier to design a good front end, etc. The only thing that will be a problem will be the number of outputs, but it sounds like you can handle that. With this kind of a design, a step down transformer will benefit, as you won't need the voltage, and it will up your current (assuming a BIG transformer is used). Look at the specs on the PA amps- they are all voltage limited- they push the big power into a 2 ohm load! Also, consider that no one builds an off line amp commercially... obviously the risk to consumers is too great. Sure, you can reason that you will be careful, but there is a reason no one is doing it- it really is unsafe. All it takes is one slip to end you, right now. If I remember correctly, all it takes is 2mA to stop your heart.
I don't want to come across as a jerk, but I have to say that your design is not synergetic. Your trying to justify building this off-line beast, when it is only messing up the design in general- just for this one purpose (getting rid of the power transformer). Look at that schematic, and consider the complexity to drive that impedance to that power level. Consider how much simpler the front end will be if you would only drive it into a 2 ohm load (and all the efficiency you will gain with your speakers). I think you will come to a similar conclusion if you really consider it all.
By all means, build your awesome system! Just make it a system with synergy, and the results will be all that much more impressive. Do more with less!
6ma @ 240V across the chest is quoted quite commonly as that which is required to stop the heart but of course, this will depend on many factors....
Extremely High Current output designs are not synergistic either because distortion rises rapidly with current output.
choice of drivers
Kilowatt,
By the way, your choice of drivers probably couldn't be considered "hi-fidelity"
You are going to get into serious lobing issues with the 10's- they're running way too high. The horns will give the same problem, unless you have some kind of an arrangement in mind. The 10's will also not disperse at the frequencies you will be running them to- they are going to beam like a flashlight, which will not sound natural. Also, 900 watts into a horn is WAY overkill! I have seen guys run PA outdoors and use 1/2 that!
Pro sound and hi-fi are two very different animals.
Your woofers are going to be loud, but they will most likely not have good extension. PA speakers are designed not to produce a lot of energy below about 50 hz, generally speaking. It causes too much of a problem with "rumble", such as mic stands moving, etc.
Of course it's perfectly ok if that is what you want- a PA system. I just want you to know that this system is a far cry from being considered hi-fi, with these components.
How about a line array with some good 6-1/2" mid woofers (with 600 watts to each array) crossed over at about 2K or less, and one big mother JBL horn with a 400 watt amp per side? Back that up with even 4 12" titanic woofers per side with a couple 1000 watt amps per side, and you would have a serious system that would most likely sound pretty decent too!
Food for thought- I put my MTM's outside in my back yard (which has a 100 acre field behind it) with my cheapy 100 watt/channel amp, and I had it less than 1/4 way up, and it carried for a LONG way. Of course, the bass is where you need the power outside, but you know my thoughts on how to do that. You also may be surprised that 80Hz crossover point outside is not always the best solution- the midbass may get lost. I've had good luck with 120hz or even higher.
More food for thought-
I once gigged out of town with my band, and the place we were playing (a large to medium sized church) supplied the PA, which turned out to be a home-made system. It was a four way system with 1- 18" EV, 1- 15" EV 1- 10" EV, and one large horn per side, all quadamped (mono). The system kicked!! It kicked major butt! It was SOOOO clean. I could feel my kick drum in my chest! We were running 2000 watts max. with 100 of the watts on the horns.
Kilowatt,
That's a given, but at the levels Kilowatt is talking about he will not only be driving a heck of a lot of voltage into his woofers, he will also be dumping some current too. I think the benefits of going lower in impedance far outweigh the problems. Of course there is a tradeoff with any design, and that may be the downfall.
BTW, is this problem as pronounced in MOSFET output stages as it is in bipolar stages?
Well, some interesting ideas. I once heard that driving into higher impedances gave better sound than into low impedances. Of course I've seen sales brochures for amps that can do 1 ohm or so say just the opposite, but you know how sales propaganda is. If I lowered it to, say, 900W into 8 ohms, I'd be stuck in some sort of in-between voltage range where 1 MOSFET in series isn't quite enough for comfort, but 2 is overkill. I'd also need a transformer or transformers. Please keep in mind that what I have right now of this amp weighs about 65lbs when full of coolant, and measures 24"W, 22"D, 16"H. It would be maybe 8" deeper after the direct line PSU was attached and be heavier too. My 4 channel Leach amp won't be much smaller, but maybe half as high. With transformers, it would add, just an edgucated guess, 250lbs to my amp. Can you lift 315lbs? Maybe if it's in a backpack, but I'd be too worn out after hauling it to do anything else. Time to get a forklift. This was my main insentive to make it direct line powered.
Maybe I can use a switching supply (or switching supplies), if I can find such a thing. That would be fine. I might also need to find a little higher voltage devices, so I can run up to maybe +/-120V. I guess wht I thought was this: Anthony uses +/-110V, but he pushes his devices to the limit, Glen (project 20kW) uses +/-115V. 160V isn't a whole lot higher than 110V. However, after reading your ideas, I would like to build maybe only 4 900W channels, I would be better off breaking up the rest of my 7200W even further, continuing with maybe a couple of 450W channels and some 225W channels too. For these, obviously, +/-160V is out of the question. Try +/-60V, also, +/-120V is what I'd need to get 900W into 8 ohms for the big ones. I can't have those heavy, bulky, expensive, power transformers, so I need switching regs with plenty of headroom. They'd also help me do away with those huge filter caps. Do you know of any 1500W +/-120V switching regs? I can't see myself making them.
What drivers do you think I should use? Xover freqs? Maybe 4 way? I've looked all over for speakers and couldn't find much better than those EV 10's.
On third thought, 8 ohms is too much. +/-65V for the 900W channels is good, unless I could put drivers in series (there are dual voice coil drivers, there are 16 and 32 ohm drivers, what's the difference between these and 8 ohm drivers in series?). Like Audiofreak said, I'd be putting more current through each device, in my case almost 3 times more, I don't like that.
8 ohms would not be the way to go, if you want to drive 900 watts. The whole point was to eliminate complexity- get rid of those series FET's. Then again, think of it this way- If you get a 3db gain with every doubling of power, what is really the difference between 750 and 900 watts, as far as SPL goes? Probably doesn't amount to anything. Now, take that 750 watts and use 4 channels each driving 750 watts into two paralleled 8 ohm woofers, and you're getting somewhere, and it would not be hard to do. You're looking at 3000 watts for your subs, which would be really nice. If you need more, you build more channels, and add more subs.
If you were to start with two drivers that are 90db- 1W/1M, you would have one cabinet capable of 123db 1w/1m with a 600 watt amp. Now, add 3 more amps driving 6 more woofers, and you would be up to 135db! Talk about earthquake simulation!
As far as the mids go, if you're interested in quality then you need to get away from pro drivers. I think a line array would be appropriate. 6-1/2" woofers would be a good compromise. If you were to use, say 8 Vifa P17wj-08's per side, you could series parallel in two groups of four for 2 95db drivers. Parallel these and you would have a cabinet with 101 db/1W sensitivity and a power handling of 560 watts! Use a 300 watt amp and you could go 123db. If it's not enought add another cabinet on top and another amp and go 129db! This is per side! 135db total for both sides!
As far as a tweeter goes, there is no good way. you can't parallel them, or you get lobing effects. A horn looks like your only option. Look at some of the top end models by JBL- but you will be looking at $500 for a driver, and maybe as much for a horn.
I still can't believe you want to go series- it just dosen't make any sense!
Is this helping you at all?
What I need is a +/-45 volt supply. It will give me 450Wx4 into sets of 4 8 ohm subs in parallel per side. The only thing I can find along these lines is Eminance Subs. Can you think of something else? For mid, I can do just what you said, but more so (those Vifas can go pretty high). 3 sets of 8 in series parallel per side instead of 2 of 4. For trebble, I can use 6 56W amps and one 8 ohm horn for each. These would have a +/-32V supply.
So here's the total recipe: for bass, 8x450W into 2 ohm amps (45V) each driving 4 subs; for mid, 6 more of them, each driving 8 Vifas; for treb, 6 56W amps each driving a horn.
Bass, 143dB peak, which is too much, but if I don't use Eminences, it will most likely be less; mid, about 136dB peak; treb, about 140dB peak, which might be too much, but I can lower the power into them. All these dB figures are per side. Xover freqs would be based on those numbers, but manufacturer's sensistivity specs are so far off that I don't see how I can expect those dB figures to be true.
Kilowatt -
You will be much happier with this approach...
As someone who used to do lots of live sound work, you are now on the right track! There is a reason that the rock tours have racks and racks of amps - redundancy combined with better sound...
The other advantage to this approach is that you can use the modules of this design for other things - i.e. home theater, party at a friend's house, etc... without taking the whole system along.
Look at EV's drivers if you're really serious. Expensive but well worth the $$$.
Steve
Steve
Yeah, I wanted to use EV 10's for mid, but SteveG said they wouldn't get me the sound quality I want. What do you think?
Yes, EV's are nice but 10" is WAY too big to go that high cleanly. And yes SteveG, MOSFETs have the same distortion rise with current output.
Just wondering, Kilowatt...
450 W from +/-45 V, you are talking peak power values all along, are you not?
I hope for your sake that you protect your ears when you test the system 😀
You will probably not find any premade switchingsupplies that suites your purposes. If I were you I would consider trying to build one. It would save you size, weight and (hopefully) money.
Good luck! Looks like a killer system!
Marcus
Marcus
No, I am talking RMS. 7200W RMS. Maybe I should raise the supply. Now that I think of it. duh!
P.S. It's all in one chassis, because I have this monster water cooling system begging me to use it, but they're all completely independent electrically, even the power supplies. It's like monoblocks on the same heatsink.
- 1kW MOSFET amplifier
