Its works, with 50v dc & 20mv bias(for test). I will push bias more higher again.
Many thanks to mr. Mile for schematic & sonal kunal for pcb design.
Please advice for optimmum bias & voltage.
How many watt can deliver from this amp, with 3pair irfp260n, datasheet say 300watt dissipation?
![uploadfromtaptalk1424944883199.jpg uploadfromtaptalk1424944883199.jpg](https://www.diyaudio.com/community/data/attachments/420/420318-3760b34c749c7101bc37aa3277190be3.jpg)
Nice work, about 300W/4R with +/-75V
It's a working amplifier,so it's time for pcb posting!Update!! Use +-56volt DC, bias 35mv. No hum, noise, & simple powerfull amp. I use this amp to handle 10" 350watt 2ohm speaker.
Mr. Mile, Can i use 2sd600/D600K instead BD139?(many fake BD series in here)
Regard
Regard
Yes many TO126 transistors can be use instead BD139... 2SD669, MJE340...
PCB NX-400
Many thanx to Sunal Kunal, he was made this.
Regard
It's a working amplifier,so it's time for pcb posting!![]()
Regard
Mr Miles, i want to ask max value for C4 & C5, can it change with 47uf? i want to build second Nx-400, but my stock 22uf is empty.
Use any value over 22uF
Nice work thole,
amp is able to drive 2ohm load at 56v.
BD139, BD140 fakes, I only buy CDIL make BD139, BD140 other manufacturer marking ones are mostly fake here. Still have few pairs of grey Philips ones.
All files for building this amp.
![cheers :cheers: :cheers:](https://files.diyaudio.com/forums/images/smilies/cheers.gif)
R3 10K in schematic is labeled 22K on layout
. Those who downloaded sprint layout file can edit it.
Corrected pdf files.
- 150W MOSFET Amplifier with IRFP250x2
