150W MOSFET Amplifier with IRFP250x2
I have a question: if I make this modifications , drivers will stay cooler .
Would it afect the sound quality?
Its works, with 50v dc & 20mv bias(for test). I will push bias more higher again.
Many thanks to mr. Mile for schematic & sonal kunal for pcb design.
Please advice for optimmum bias & voltage.
How many watt can deliver from this amp, with 3pair irfp260n, datasheet say 300watt dissipation?
Update!! Use +-56volt DC, bias 35mv. No hum, noise, & simple powerfull amp. I use this amp to handle 10" 350watt 2ohm speaker.
Mr. Mile, Can i use 2sd600/D600K instead BD139?(many fake BD series in here)
Regard
Nice work thole, :cheers: amp is able to drive 2ohm load at 56v.
BD139, BD140 fakes, I only buy CDIL make BD139, BD140 other manufacturer marking ones are mostly fake here. Still have few pairs of grey Philips ones.
All files for building this amp.
R3 10K in schematic is labeled 22K on layout 😱. Those who downloaded sprint layout file can edit it.
Corrected pdf files.
  • NX - 400 3W Components.pdf
  • NX - 400 5W Components.pdf
