100W Ultimate Fidelity Amplifier
So I finally revived A40 .. square at 20khz and 50khz...very clear sound with good bass..
Calculate it.
29Vac gives ~ 1.4*29 as your loaded DC voltage, i.e. around 40Vdc
two times 29Vac gives around +-40Vdc when loaded.
Assume 4V lost through the amplifier when delivering maximum power.
i.e. maximum output ~35Vpk
Maximum power = Vpk²/Rload/2
i.e. 35²/8/2 = ~76W into 8r0 dummy load. If you build the PSU and amplifier properly.
