HELLO APEX SIR ANY CHANGES IN PCB LAYOUT.
CAN U SHARE THE PCB LAYOUT IN PDF.
Speaker Terminal with DC Protect
HELLO APEX SIR
CAN U SHARE THE BOTTOM LAYER IN PDF.
HOW MUCH POWER OUTPUT IT CAN HANDLE?
HELLO APEX SIR
Speaker Terminal can be use with any power.
SO I CAN USE IT FOR AX-14 AND B500 WITHOUT ANY PROBLEM AM I CORRECT?
I KNOW THIS IS A SPEAKER PROTECTION CIRCUIT.
CAN U EXPLAIN THIS CURCUIT.
This DC ptotect can be use if rail voltage is over +/-40V DC, and if there is fuses in rails or amplifier output. If on amp out exist over +35V or -35V DC, triac conduct and short circuit speaker output.
THANK U VERY MUCH FOR YOUR COPERATION.
Too much questions, would you diy something?
AX-16 Pcb size 106.5 x 68 mm
Thanks, is this red line jumper from 'J' to 'J'?
yes red line for jumper 'J' to 'J'
Do you build AX16 with this pcb? Can you share your expirience?
D
Deleted member 148505
Hi apex,
Can I replace 2SA1837 and 2SC4793 with MJE350 and MJE340?
thanks
No, use some TO220 drivers like TIP31C and TIP32C.
BECAUSE YOURE ARE A SIR, AND I AM A STUDENT THATS WHY I AM ASKING TOO MUCH QUESTIONS.
It's OK to ask questions about building amplifier, this is diyaudio forum. You can't learn much here, it's not school.
apex, a little question,
if i were to use "Na2nk" pcb, and use +-75vdc with 3 pairs of output...
Q. Will it be stable? or i should change transistors? if, which is it?
No need to change anything, just use 3 pairs with +/-75V rail.
Yes i bulid with those pcb, it's give me new experience for listen the music, although i only use local speaker not hifi speaker. and now my old diy amplifier must retired all
Mr. Mile i very interesting for build AX500 now after taste sound quality of AX16, please share the AX500 project.
Regard
Regard
What is 'local speaker'? Can you post some pictures?
- 100W Ultimate Fidelity Amplifier
