DIY Class A/B Amp The "Wolverine" build thread
Indeed, Neurochrome's soft start is Rolls Royce. All features you could think of and max 2kVA transformer. A beefier standby supply is about all I would want (0.5W is a tad weak). Adjustable LED brightness is a very nice touch.
I'm curious how much power you need. Also curious what you're using the standby supply for. Just so I can better understand the end application, that's all.
Tom
Reactions: Mainframe
Some progress yesterday. I configured the DIYaudio soft start, 2x Antek transformers (stacked on top of each other), and 2x DIYaudio PSU (also stacked on top of each other) with the success for end result of +/- 71.5VDC! I haven't figured out why the -71.5VDC side of each PSU won't light the LED, maybe I installed it backwards? I can't wait for the new boards to be delivered!
Any suggestions on where to source good signal input wiring? I watched Daniel's wiring video again and the closest thing I find on Amazon is the following, does it look alright?
https://www.amazon.com/Conductor-Shielded-Stranded-Spindle-Transmission/dp/B0D9JWWGKT
I'm not certain what the Wolverine Team thinks about this, but AWG 18 seems very heavy for signal wiring to me. I'm using a much lighter gauge Mogami cable that is shielded. In the U.S. check out Markertek. They sell to the broadcast industry. They have Belden, Mogami, Canare all sold by-the-foot for reasonable prices.
Reactions: RodimusPrime98
Stop using giant cigar sized patch cables inside your beautiful hand crafted, metal, shielded amps and preamp projects.
Stop The Insanity - Susan Powter (Just Google her or see YouTube)
Go with a 1533 28AWG or similar. Keep it simple and small and pretty looking.
Giant cigar cables are for Woodstock in the mud and Speak On speaker connects.
May I suggest you use a clamp like the *MCC-1-01A-BK?
*Use a tiny drop of high temp epoxy glue with these little cable clamps to keep them in place but do so with caution. Not easy to change after the fact without leaving cosmetic damage.
You can buy 1533 shielded cable anywhere for dirt.
have the dimensions of the heat sinks
1. From the main heatsink to the top of the new input capacitors is 37mm
2. From the main heatsink to the top of the IPS heatsink is 53mm
3. From the main heatsink to the top of the Pre-Driver heatsink is 42mm
4. From the main heatsink to the top of the EF3-3 or EF3-4 Driver heatsink is 62mm
Thanks Stuart!
Looks like everything will fit inside the slightly larger version of the chassis even with the bigger shielded transformers.
When I'm done modeling everything I'll post up all the STEP files for everyone to use. At least for the universal components.
Thanks Stuart!
I would recommend that you dont put the second transformer adjacent to the input stage area at the back panel of the chassis.
Perhaps consider one larger transformer or two stacked transformers towards the front panel area of the chassis where the less sensitive area of the amplifier is.
The bulk capacitance can go towards the centre/back panel. This layout has proven to be successful in many amplifier builds.
Hope this helps, just trying to save you some dramas
-Dan
Hi Rodimus, for signal wiring I used shielded twisted pair and there are many iterations of it around, it is commonly used as XLR cable.
Stuarts post above shows and describes the method. See Canare L-2E5 (twisted pair) or L-4E5 (star quad) both are shielded flexible mic cables.
You dont have to go crazy with the wire gauge. There are some nice star-quad with a a braid floating around now but realistically it is only a few cm to the input of the amplifier anyhow and shielded twisted pair is sufficient.
-Dan
