Indeed, Neurochrome's soft start is Rolls Royce. All features you could think of and max 2kVA transformer. A beefier standby supply is about all I would want (0.5W is a tad weak). Adjustable LED brightness is a very nice touch.
The diyaudio speaker protection board simply requires the appropriate AC voltage. I believe the power supply is on the speaker protection board.How are people powering boards (speaker protect, etc)? I have extra 18VAC and 12VAC from my Antek transformers that I would like to use but not sure the best way to convert it to DC in this low noise area.
Boards have been manufactured but there may be some extras. Read first post of 5th group buy thread and send order form to Stuart and see how you get on
I see the boards are about to ship out so maybe pointless but does anyone have the dimensions of the heat sinks and the relay off of the board?
I have a little bit of time today where I can start laying this stuff out inside of my little chassis (toroids going external to the chassis)
Thank you! Going searching for the info nowIf you purchased the heatsinks from the group, they should have dimensions in the post. Otherwise, you'll cut them to size. The cap will be based upon the part you choose, and the dimensions can be found in the datasheet.
Are you SURE you want to do that? I'd suggest using a larger chassis.toroids going external to the chassis
Yeah, I'm pretty sure. I want to be able to keep the noise as far as away as possible. Putting 2 giant noisy components right next to sensitive circuits is anathema to me.Are you SURE you want to do that?
The Wolverine has been built many times with superb results having the mains transformer in the same chassis.
Complicating the build with an externally mounted transformer doesn’t really gain any advantage here.
Well, I have had an issue with one amplifier before that had a toroid. I have since shielded it and still have idle noise. Somewhere I came across a bunch of pictures of someone building a wolverine. If you go down the timeline you'll see they started with an unshielded transformer and then moved to a shielded one. Why would they do this if not for encountering noise?The Wolverine has been built many times with superb results having the mains transformer in the same chassis.
These exist, they are twice the cost of an unshielded toroid. If I could be guaranteed zero noise using this then ok. However, as aforementioned, I shielded another toroid and it just knocked the noise down, it did not completely eliminate it.
Not to mention how much physically large the chassis would need to be. Here's a reference of the size difference. I could place the toroids elsewhere which would give me more flexibility in positioning of the system, they would be less noise, smaller footprint because I could use the unsheileded ones, I could 3d print the toroid chassis so I save money not buying a giant chassis (the wife isn't thrilled about a giant ugly metal box in the TV room), etc.
More flexibility
The trannies themselves do not cause any noise to the amp.Yeah, I'm pretty sure. I want to be able to keep the noise as far as away as possible
The main source for noise problems is usually the swiching noise by the rectifiers, but there are good ways to deal with this.
Keep the trannies in the chassis fir safety reasons.
The diyaudio speaker protection accepts 12vac? I assumed it was 12vdc. Does the DC speaker protection boards from the group buy, do they require 12vac or 12vdc?The diyaudio speaker protection board simply requires the appropriate AC voltage. I believe the power supply is on the speaker protection board.
Now you would have 2 chassis to deal with and more cables. A plastic housing for power transformers is not something I would do.….I could 3d print the toroid chassis so I save money not buying a giant chassis (the wife isn't thrilled about a giant ugly metal box in the TV room), etc.
But, some say tomāto and some say tomăto.🤣
@Bmsluite,
You are taking your observed sample of 1 for a different design and applying the findings to this (different) design. And then coming to the conclusion that this experience is more informative than of 100's of builds of this design that say otherwise.
If you choose to use a separate chassis, do it because it's what you want to do. This is a hobby after all, and if that's what's makes you happy, do it. However, do not incorrectly assume it's going to fix a problem that 100's of builds demonstrate does not exist.
- DIY Class A/B Amp The "Wolverine" build thread
