DAC AD1862: Almost THT, I2S input, NOS, R-2R
@CNOracle , do your board use the I/V design on the datasheet?
Yes, I used the I/V scheme shown on the datasheet.
It works great.
Reactions: zoom777
Please forgive my not absorbing this threads nearly 600 pages. I am trying to mate the Miro 1.3 version of the board with JLSounds board, which is a newer galvanized isolated unit. The .pdf on their site and lack of DAC jargon has left me with a number of questions. It looks like the ideal board is the one with adapter and Opamps outputs, but I cannot find the gerbers for one that I have seen be created here recently. In any case, I could use a little help assuming I CAN hook up these two boards.
I am not sure what pins go where for Miro's 4,2...
Does the 11->4, and 15-2?
I wish to just do thse two things, and assume that jumpering the JLSounds board per screenshot will work H1.1->H3.17, H1.2->H3.19.
If someone can tell me if this setup will work good, and if so, if any errors (assumed) in my analysis.
You should try the 2 or 4 layers version with the jlsounds header. You have just to plug in the usb board (stack). You should use the galvanic version with the front end feed bu the usb plug in a first time and the clean side with a PS or the +5V of the digital side of the ad1862 board.
I have a made the 4 layers pcb, smd focused, (for JLSOUNDS plug in or IanCanada I2S to PCM boards) but I sell it. Miro has made a 2 layers with the header your friend migth have given to you and I have made a 2 layers from it with smd for op amps. Gerbers inthe thread but don't remember where something in a post >8000 number. But the miro version is perfectly fine if you want to use a dip 8 op amp or if you hack the signal from it.
On the first page on this thread you have a link towards his blog that is very usefull with links going into the thread and also how to use the JLSOUNDS. Just few pages.
Hello,
Just a moment of inattention... I soldered the 74HCT164D in the wrong orientation and damaged two pads while removing it. 🙁
It looks like the damaged solder pads are unused — am I correct?
Could you please confirm whether the chip will still operate correctly?
Thank you in advance!
You can try the one you have, and replace if it doesn't work. Easy way to desolder it (without heatgun) is to bend copper wire to U shape, place it above all pins and put solder on it and all the pins to cover. Then heat up the wire so it will distribute heat across all pins and you remove it with tweezers.
  • Thank You
Reactions: Areek2
@Tea-Bag
1. I assume this is just for initial testing only? It is better to eventually have their separate individual supplies
2. Have you soldered the smd shift register ICs? Since you have the JLSounds board, you can actually skip them.
However if you insist on the i2s format source, the shift registers must be used and please use the following configuration, assuming that your JLSounds board is VIII (not the FIO version) :
So you need to remove jumper 4 from your board.....
A picture of your JLSounds board will be good for verification of the version you have.
Reactions: 6L6
Cut open JP1 and JP2. DNP J9 (this will remove the +5VD routing to the shift register ICs)
And of course DNP IC1 ~ IC6 and C1 ~ C6.
JLS 9 -> DAC DR
JLS BCLK -> DAC pin 4 i2s input
JLS 13 -> DAC DL
JLS 15 -> DAC pin 2 i2s input
JLS 2-16 -> DAC Gnd at i2s input
(any one)
Reactions: 6L6 and Tea-Bag
Thanks for looking at this. I have been offered a board by another member that mounts jlsounds on top of it. It will likely be less complicated for me.
Here is the jlsounds board. The plan is to make a seperate 5v supply for jlsounds board after making sure I can get it working with basic supply first. New dac board will be the following design, and looks to be copy of one I heard earlier this year and enjoyed a lot.
Reactions: zoom777 and 6L6
