8" high efficiency midbass driver suggestions
FWIW:
"Spec sheet, FS = 66Hz, Zmax at FS = ~50 Ohms.
Out of box, FS = 80Hz, Zmax at FS = ~58 Ohms.
Breakin routine, 10 minutes at 30Hz, 20V RMS, Excursion ~6mm
Allowed to cool 20 minutes. (Motor structure was warm to the touch.)
Broken in, FS = 68Hz, Zmax at FS = ~50 Ohms.
Measurement method, true voltage source impedance check, ARTA Steps 1/48'th octave. Drive voltage 2.83VRMS."
Reactions: Zvu and scholl
This Beyma, I assume?:
View attachment 1473914View attachment 1473921
What 'problem' are you referring to?
Yes. They changed the surround to a stiffer one without telling or changing the datasheet. The new driver measures very different - nicer in the resonant area but double the THD in the normal area. Also Qms went down significant and in my listening test the driver showed less detail in the music. Even the distributor didn't know and asked in the factory what's going on.
This looks like a severe surround reflection mode and its quite pronounced.
When I remember right it's just H2 from the membrane resonance (half the frequency of the resonance) - it will go away with a passive crossover or a series notch (Purifi paper).
I wanted to build my cinema speaker with the Beyma and it took 7 samples of 8" until I found a new one which I was happy with.
The nearfield distortion tests at 2.83V, 4V, 8V, 16V RMS were done by Scott Hinson.
I respect Scott a lot for his work but these measurements ...
He included a warning:
"Do not attempt to do nearfield distortion tests like this unless you understand how loud nearfield SPL measurements can/will be."
In this case the SPL at ~1/4" from the dustcap was in excess of 150dB.
A special purpose high SPL Josephson microphone was used (C725, US$ 10.250,00), capable of measuring 165dB @ 5% THD.
This was about 15dB under that so the microphone distortion should be under the noise floor of the measurement.
That's rubbish. A condenser microphone doubles H2 (which is dominant) every 6dB of SPL.
A studio microphone is specified at 0,5%, measurement microphones sometimes with 1% THD. But 5% ... That's 2,5% at 159dBSpl, 1,25% at 153dBSpl, 0,5% at about 145dBSpl. When he had 150dBSpl during the measurement ... the mic THD will likely have some influence.
Here some measurements from measurement microphones at 1kHz:
A GRAS 40BD has about 2,5% THD at 160dBSpl and would have 5% THD at 166dBSpl - costs about 2k and is really no special mic. One of the B&K 1/4" has even less sensitivity and would probably get in the 2% THD area at 165dBSpl.
Scott also tortured the driver with 10 tone test signals in a 100°F (38°C) garage for hours and compared it to a 7" high-end woofer, probably something in the range of a Scan-Speak Illuminator or SEAS Excel:
I know the ScanSpeak 8" drivers and NO WAY the B&C tops them at "normal" levels. Maybe Purifi is a little better.
This is the metal membrane 8" 22W/8857T00:
8Vrms is 9dB louder as 2,83Vrms. Sensitivity is specified 86dBSpl/2,83V, so at 8Vrms we land at the 95dBSpl curve (@400Hz). THD is below 0,2% in a wide range. Even at the limit what they are able to deliver (about 25V) they stay below 1% THD - these are exceptional drivers!
I'm sorry to say but either these measurements are not reliable or the driver is in terms of THD just average. But I would not trust these measurements.
More losses due to increased damping in the suspension.
It's a trend in audio, even more so in hifi.
That's why I don't like ring radiator comp. drivers and dome tweeters with thick surrounds.
They measure well, but fail to properly reproduce the input signal (slightly exaggerated for clarity).
It's also one reason why Stanislav Malikov (BlieSMa) uses thin surrounds.
@IamJF That's extremely frustrating. Consistency is everything. If you can't count on driver specs being accurate, the driver isn't useful IMO.
To evaluate a driver's purpose and usefulness, I always purchase at least 3 drivers to determine if it has sufficiently consistent properties when used in non-matched pairs.
I used a few of them for an industry project, had 1-2 in spare and did my measurements and a prototype. Then ordered 3 new ones - and these had the changed rubber surround. No way to get the old ones. The complete project ... back to the start.
But at least I detected the PA-driver low SPL strange behavior of some drivers and know a lot about 8" drivers now 🤓
Btw, the old 8P300 had a Qms of 15-20! The new one less than half ... and nobody cared or noticed.
I contacted a German studio monitor manufacturer who is using this driver a lot and the answer was "we don't care, we correct with DSP" ... 🤔😳
Reactions: profiguy and Zvu
Measurements of any kind remain (in my view) a tool to indicate performance; nothing more and nothing less.
A complex world lies hidden beneath the measurable values.
It therefore doesn't surprise me that Beyma was not immediately able to provide an explanation for your findings.
Purifi drivers are top notch, in terms of measurable performance. I mainly see the 'limitations'.
These drivers have been developed with modern (marketing-induced) dogmas in mind, ultimately inexorably limited by Hofmann's iron fist.
Reactions: NeonDriver
D(efinitive)S(olution)P(rovider).
Funny how supposed audio professionals believe they can correct (solve?) something in the electro-mechanical-acoustic domain by using digital tools.
It may be a bit of a bold statement and it's not intended to cast doubt on Purifi's innovative R&D.
Bruno is the most brilliant audio engineer I know and I don't doubt Lars Risbo's qualities either.
Ultimately, every designer has a specific philosophy, considering the intended application and performance level.
While Japanese engineers tackled the breakup of a large aluminum dome in a well-thought-out mechanical way 30 years ago,
Purifi opts for (rather complex) solutions in the crossover (perhaps they could have solved this easily with DSP 😎).
Note: this does not eliminate the (material) signature of the cone, but only reduces the excesses inherent to the material (breakup peaks).
@Ro808 Purifi drivers are very expensive and not that sensitive.
One should be able to expect a minimum standard of tolerance and performance, even if some of us don't care or can't perceive it. That's no excuse. For those of us who don't use DSP, it shouldn't be expected we tolerate sloppy production practices.
"Extremely clean SPL and distortion response and no more sign of any resonances. It is a challenge to find a matching tweeter with such low distortion."
Now there will undoubtedly be people - especially on a particular forum - who genuinely believe that at such low distortion levels, there is little or no audible 'coloration' of the reproduced signal.
Those folks who 'pursue absolute transparency' and therefore rely solely on measurement data.
Massive ignorance is hard to eradicate and this is illustrated by the state of the world.
I was pleased to notice that Yevgeniy Kozhushko (HiFiCompass) at least understands what determines the subjective experience:
"So, we got to a very interesting point. You can do measurements and discuss them for a very long time, but no one really knows how they are related to our subjective feelings in general. Undoubtedly, there is some kind of correlation - a flat frequency response indicates the absence of obvious humps and dips, which lead to an ear drilling or the bleaching of the music instruments and distortion of the timbre. Low non-linear distortions can increase the resolution of the system, reduce the amount of "mud", especially at high volume levels. The radiation pattern may give us a hint about spatial characteristics of the being shaped virtual sound picture. In fact, that’s all. Not very much at all.
There are many more nuances that can not be measured, but leave a noticeable imprint on the sound signature of the speaker. Many people claim that the main factor affecting the sound signature of a speaker is a quality of its magnetic system and the membrane material is secondary. My point of view on this question is the following: the magnetic system is undoubtedly very important, a lot depends on it, especially the overload capacity of the speaker, but the membrane material properties are the main factors determining the speaker's “breed”, character or sound signature. Namely it is the combination of its unique characteristics - the Young modulus, density and internal damping and, possibly, something else that determines the unique sound signature that we hear as its own “voice”. Believe me, each material sounds differently."
That each material got it's own properties that can affect sound is true, but that you can't measure it is not i think.
But you need to look more closely to the distortion profile, especially IMD, and to the resonances, that varies with cone material, and is not only limited to the one big peak, but also a lot of smaller arround them. But i firmly believe you can measure more than you can hear, you just have to have the right tools and knowlodge to know how. I learned a lot by studying Kippel measurements and try to linkt hem to what i hear (of certain speakers i know well).
But there is also a lot of snake oil mysticsim arround this, where subjective data is presented as objective for commercial or ego reasons. Or people who hear something but don't know how to measure it, so they invent somthing to explain...
Reactions: IamJF and Azrael
Drivers without noticeable acoustic signatures do not exist. There's always some hint there of acoustic character, even when distortion levels are diminishingly low. What you hear isn't the absolute amount of distortion. Its the balance and proportions of HD, including their types.
Purifi likely has the most neutral sounding drivers on the market. Their designs are a long culmination of engineering experience from some of the best people in the business. Its hard to obtain cleaner results than what their drivers are capable of. Impossible? No, but very difficult.
Bliesma and Purifi are IMO the 2 current best companies designing drivers for the lowest possible distortion and highest amount of resolution. Seas and ScanSpeak are right behind them, but still have some amount of "personality" embedded in their products.
Starting with a clean slate is difficult in this business. You need the best available engineers which have been involved the business for decades. Purifi is likely the most advanced company with the most seasoned engineers which have accumulated knowledge and experience from other established and respectable driver companies.
.... But i firmly believe you can measure more than you can hear, you just have to have the right tools and knowlodge to know how...
I strongly disagree with this belief of yours.
If this was true, you could know in advance how a loudspeaker sounds just from measurements alone. No listening would be necessary ever. Since that isn't the case, either no one knows how and/or what to measure, or the claim is false.
Well, there is one factor that you can't measure, that is personal preference, which is subjective by definition. There hearing is the only way to judge. But all others you can measure i'm quiet sure.
Personal preference is a big factor, that is why there is no one system that works for all. You can predict trends (like Sean Olive and Floyd Toole did for Harman), but those are generalistic statistic trends, not what fit you as a person. It's a handy study for commercial speaker designers to find what most will like, but nothing more than that in my opinion.
My choices are also defined by that, i don't like BE tweeters as they sound way to sharp to my ears, while others don't want nothing else anymore. It's a personal preference, not an objective quality that makes the difference here. I in general also like paper (or fiber) woofers a lot more than metal cone woofers, altough there are exceptions. But again, it's personal preference. And why i like it is measurable if you know what to look for.
Reactions: Azrael
@waxx When you want a speaker to purely ENJOY music metal domes and BE is not the right choice. I always talk in length with people when designing a speaker what their listening expectations are and what's the room the speaker will be in. So I actually bought a pair of T25S for a project which I would never use for myself 😀
But in my living room cinema - I also use a ring radiator (which I like way more as soft domes) and (a very detailed playing) paper lowmid - works perfect for everyday listening.
@Zvu You can predict 90% of how a speaker sounds with a spinorama and detailed THD measurements and some details like port resonances and midrange leak. And you need to know the room. I always do presets from measurements and then give a listen and comparison - and you get very close with measurements. But yes, the last 10% are preference or some driver signature/sound (like Dayton metal 2" - they always sounded to loud/intrusive and I took them back 1-2dBs to fit the rest).
