@Ro808 Thats a dramatic difference considering the cone diameter deficit, it's in line with my perception on the 8NDL51. The lower mids on up are musical, dynamic and highly resolving. This driver will take quite a bit of input before it starts to compress or strain. Very few mids can match the detail retrieval, even above the typical usage range. On top of that, as a range limited woofer with a bit of EQ on the low end, it will surprise in terms of how much air it can actually move in a ported cab. That's despite this enclosure type not sounding as snappy as a smaller sealed box in midbass applications.
A small mod that helps with lower level motor noise on the 8NDL51 is adding some 3/16 holes to the spider's sides. This decompresses the spider underside so the air being pushed past the VC gap isn't as audible. I wouldn't do this on a continuous very high output midbass application as it would compromise power handling, but in most situations its a non issue. A larger diameter, blunt tip on a soldering iron makes quick work of this. A total of 8 holes are all that's needed.
How do folks think distortion of the 8NDL51 compares to the 8MBX51? Sonics? Are there any similar measurements for the MBX?
@Ro808 - are there any THD over frequency measurements at different levels from 8NDL51 available? Something like that:
Yes.
16V is > 150 dB at the cone.
A proper indicator is the sound of the naked driver - full range without any filtering, mounted in a vented cab, tuned at (about) 60 Hz.
The only 2 way I've ever built with the 8NDL51 was with the DE360 on the ME20 horn as an MTM. I dont have crossover specs anymore being i designed it just before my last PC's hard drive crashed. I can tell you I crossed it at 2.5k 3rd order for a PA application. It had hifi clarity over 110 dB at 5 ft distance crossed to a sub above 100 hz. Fullrange with the box tuned to 60 hz, the low end was very surprising, almost unbelievable. One of these boxes would comfortably take 400W all day. The DE360 is a ring radiator and sounds like a large HF dome on the ME20 horn. There's only a small 3 dB peak at 3.6k on the 8NDL51 that needs to be flattened with an LCR to get the last little bit of clarity, but in MTM arrangement, the mid peak will shift depending on baffle width, so there's more fine tuning needed if you want the last word in flat FR.
You hit the proverbial nail on the head.@Ro808 Thats a dramatic difference considering the cone diameter deficit, it's in line with my perception on the 8NDL51. The lower mids on up are musical, dynamic and highly resolving. This driver will take quite a bit of input before it starts to compress or strain. Very few mids can match the detail retrieval, even above the typical usage range. On top of that, as a range limited woofer with a bit of EQ on the low end, it will surprise in terms of how much air it can actually move in a ported cab. That's despite this enclosure type not sounding as snappy as a smaller sealed box in midbass applications.
Your modification may be useful for some applications, but absolutely not necessary for 'hifi at home'.
In addition to the measurements, there's a deeper level at which a driver and the intended application can be considered.
How did you get those measurements? Nearfield? What mic did you use? What's the noise floor?
Cause that's exactly what I don't want to see from a driver - THD at lower levels keeps the same and don't goes down. Ist it H3 at lower levels or H2?
SB 10" woofer also behave that way (measurements in the forum) and 18Sounds 8NMB420.
Or Faital 8PR200 in the midrange:
The old Beyma 8P300 (with the flexible surround) doesn't have this Problem and sounded really good:
I'm really open to suggestions . is the ath4 easily obtainable?Do you have a horn in mind - an Ath4 perhaps?
that's sounds like an awesome speaker ! are you saying that you needed to be 5 feet away for the output frome the woofers and tweeter to combine properly ? could you angle the woofers slightly so it could be used at closer distance .The only 2 way I've ever built with the 8NDL51 was with the DE360 on the ME20 horn as an MTM. I dont have crossover specs anymore being i designed it just before my last PC's hard drive crashed. I can tell you I crossed it at 2.5k 3rd order for a PA application. It had hifi clarity over 110 dB at 5 ft distance crossed to a sub above 100 hz. Fullrange with the box tuned to 60 hz, the low end was very surprising, almost unbelievable. One of these boxes would comfortably take 400W all day. The DE360 is a ring radiator and sounds like a large HF dome on the ME20 horn. There's only a small 3 dB peak at 3.6k on the 8NDL51 that needs to be flattened with an LCR to get the last little bit of clarity, but in MTM arrangement, the mid peak will shift depending on baffle width, so there's more fine tuning needed if you want the last word in flat FR.
The nearfield distortion tests at 2.83V, 4V, 8V, 16V RMS were done by Scott Hinson.
He included a warning:
"Do not attempt to do nearfield distortion tests like this unless you understand how loud nearfield SPL measurements can/will be."
In this case the SPL at ~1/4" from the dustcap was in excess of 150dB.
A special purpose high SPL Josephson microphone was used (C725, US$ 10.250,00), capable of measuring 165dB @ 5% THD.
This was about 15dB under that so the microphone distortion should be under the noise floor of the measurement.
Scott also tortured the driver with 10 tone test signals in a 100°F (38°C) garage for hours and compared it to a 7" high-end woofer, probably something in the range of a Scan-Speak Illuminator or SEAS Excel:
Lots of info in this (long) thread.I'm really open to suggestions . is the ath4 easily obtainable?
There are other options, such as DrBA's horns.
Of course, there are also plenty of factory-made horns available in (online) shops.
Stupid mistake🤣
It's either a C550F, but more likely a C617 with Gefell capsule.
Printable design files are available at: Advanced Transition HornsI'm really open to suggestions . is the ath4 easily obtainable?
You can pay a service to print them for you. I found it economically feasible to just buy a printer, learn to use it, and print my own. More in the spirit of DIY, too!
Bill
Hello ! Perhaps ?
https://www.centroelettronica.net/a...21cm.-medio-basso-full-range-800w.-max.-8ohm/
Sincerely !
Laurent
Sincerely !
Laurent
- 8" high efficiency midbass driver suggestions
