55Lx44Wx23H mm - Mind you some people are diehard no SMPS. It's an option anyway if you want compact.
Do you have a part number for this bad boy?55Lx44Wx23H mm - Mind you some people are diehard no SMPS. It's an option anyway if you want compact.
Tested the boards with the bench power supply. Both channels working. Time to order the Cobra smps. Have a good weekend Wolverine gang!
TMPW 5-112-T - it was one of the smallest screw terminal panel mount designs I could find, and 5W was enough for my speaker protects. (I forgot to add an aux winding to my toroidy order, and tbh didn’t really have the room for another rectifier board anyway). You will need to make sure any auxiliary supply for your housekeeping/protection has enough wattage to cover everything.
There are loads of alternative styles, shapes and brands of micro power supplies. Check out mouser.com or DigiKey - products - power - power supplies - AC/DC power supplies to find something that suits your build.
