MF A1, Kudos to Tim de Paravicini, Ode to my Youth, Babelfishing
Not as much progress as hoping, but some is good. Found out too late that the tap I was using is the wrong thread, (0.6) so needed to chase the holes with a hard steel screw and ‘bend’ them to 0.5 . Went out to buy a new tap, three stores, nobody has smaller than M4. Ugh. Will have to wait for order from Bezos’ bookstore.
Will get out the bench PSU and fire this channel up.
Is there a point in time when Tim stopped developing complementary transistors push-pull amplifiers? It may well be that at some point he too became aware of the physical, "objective" "reality", the audible difference between identical and, above all, non-identical components. Unfortunately, we can no longer ask him about this)-;
From my (limited) knowledge he was working on solid state amplifiers into the late 90's. Tim liked novelty in circuit design, so unlikely to design a derivative circuit, and even if he was working on a less novel circuit, would like to tweak and optimise. His advantage was a deep knowledge of how everything worked together in a circuit, resulting in petty much everything he touched sounding decent or better. He was in general not that concerned about components, but was quite aware that some types were better than others. He was agnostic on SS v vacuum, and not adverse to dropping in a little bit of sand if it was of benefit. He said he used tubes for commercial reasons. IMPO dP 's "preference" in sound quality was more to the dynamic / transient end of the spectrum.
Reactions: 6L6
can't wait to finish mine but too much work 🙁
In the meantime listening to Zen's version of M2 (it's easy to have fun when spkrs are happy with few watts)
Reactions: chakija and 6L6
All of the following applies, particularly 'fire' if you were FAB (fearless amp builder) with the bias:
Modern slang terms for "cool" are varied and depend on the context and generation. Words like "lit," "dank," "dope," "fire," "on fleek," and "savage" are commonly used to describe something cool or impressive. Gen Z slang also includes terms like "gas" (meaning cool or awesome) and "slay" (meaning to do well or be impressive).
Here's a breakdown of some popular terms:
  • Lit: Means "lit" or "on fire," implying something is great or awesome.
  • Dank: Similar to "lit," it means cool, great, or awesome.
  • Dope: A general term for something cool or impressive.
    • Fire: Means hot, trendy, amazing, or on point.
    • On fleek: Implies something is immaculately executed or perfect.
    • Slay: Means to do well or be impressive.
    • Gas: Gen Z slang for cool, dope, or awesome, or to hype someone up.
    • Copacetic: A word used in the 70s and 80s to mean satisfactory or agreeable.
    • Groovy: A slang term that means cool, excellent, fashionable, or amazing, depending on context.
    • Rad: Short for radical, meaning cool or awesome.
    • Phat: American slang for great or awesome.
    • Fab: Short for fabulous, meaning extremely good.
Reactions: 6L6 and flocchini
