Good question:B) Which belt are you using and where did you get it from?
- good one, tight, is from generic electronic store, guaranteed made in PRC
- loose, funny ones are from HIFI audio store, don't remember the brand
Dont know, yet.that 0.5sec period chart looks super clean and regular. what is your ratio of platter to pulley size?
it could be some travel procession of the platter bearing. I have seen a fine line between how smooth a platter bearing is vs how tight the bearing sleeve tolerance is.
On the good belt graph you see just random "hair" of noise which is quite normal on all TT's and at this one very small.
Then I just change belt, and get very precise 0.5 sec intervals.
Pulley ratio is about 13.8, so suspected times are 1.8 sec (platter 1 turn) 0.13 s (one motor turn) and 0.016 s (8 pole pairs in motor)..... 0.5s +- doesn't fit anywhere, even close.
I think if it is to bearing it would show it with any belt.
Nothing to be sorry about. I invested so much time in making TT that few hours more dont mean much, at least we made small progress in understanding performance results of surface treated pulley...That looks very regular in #317. You know the picture I mean; that must be trying to tell you something. Other than that, looks like the drain cleaner isn't such a good idea after all. Sorry about that.
Is it simply an undamped oscillation set up by compliance of the belt and mass of the platter? Agreed, something has been learned about pulley surface finish. Just not sure what.
By the way, my plan for (VHS) capstan motor having slimmer shaft and only a sleeve bearing below is to replace the shaft with a 4mm shaft taken from a floppy drive, fit pulley on shaft and machine it in place (this assumes I can get the shaft concentric in the lathe). I also intend to fit lignum vitae sleeve bearings (salvaged from old lawn bowls) at each end of the shaft. This will make for a slightly awkward support structure above and below the motor, a little like the idler support for a Garrard 301, but I don't mind.
That could be explanation. For me at the end doesnt matter much as with different belt it is completely different picture.Is it simply an undamped oscillation set up by compliance of the belt and mass of the platter? Agreed, something has been learned about pulley surface finish. Just not sure wha
we learned at least that it doesnt help to etch, not like this anyway 🙂
I really envy you for having lathe at home!
Can you make a sketch what you plan to do? 2 slot-less motors from beta-cams (one is in #308) already have 5mm shafts, but ball bearings need to be changed for bushings, might be a suggestion?
btw, are you measuring speed with a record on, and the needle on the record?
that tiny little bit of stylus drag is meaningful, and you will likely see even better numbers. my platter is about 6kg, and I still see WOW go from 0.1% to about 0.05% when the needle is down.
anyway, once you are in the speed variation less than +/- 0.1% and WoW around 0.05%, it is pretty darn good!
I don't trust this rotating smartphone measurement principle. If you place the phone off-centre, the angular velocity of the sensor fluctuates within a revolution. See my measurements, the first is about centered, the second is close to the platter edge. It is impossible to perfectly centering, and the position of the gyroscope within the smarthone is unknown. I suppose it should be placed right on top of the spindle.
I used an ice cream bowl with a hole in the bottom.
Thanks Jayme, yes, I also think it is wonderful. Now im just touching some in depth details, but very happy with what it is, repeatable WOW under 0.05%, reaching 0.02 is fantastic, particularity for belt drive.btw, are you measuring speed with a record on, and the needle on the record?
All latest measurements are without LP, I was trying and could not measure any meaningful difference between needle on the record and in the air, posted that in #267.
My platter is similar weight, 6,5 kg, but I don't know how the rest of your player is designed.
Hi Laszlo,I don't trust this rotating smartphone measurement principle
At beginning I was also skeptical, but more I use it, more I trust it and like it.
I get all the same measurements regardless of phone position on the platter, within 0.01% which is threshold, tried that several times. Dont know why you get different depending on position, and such big one....
In post #253 I showed 2 different phones measuring at same time, results pretty close.
By the way, roll of masking tape or duct tape makes better stand for phone 🙂
I don't know if it is against the forum rule to cite this discussion:
https://audiokarma.org/forums/index.php?threads/thorens-td160-wow-flutter.1007607/
Perhaps because of asymmetric load on the platter.Dont know why you get different depending on position, and such big one....
- Analogue Source
- Limestone turntable, help needed with motor and drive
