What makes a "Midrange Driver" a Mid Range?
The rectangular planar driver has completely different directivity from a circular cone driver, so that may be a factor in how it sounds different.
I based this statement, because, based on my small, directivity study, a rectangular ribbon ALWAYS has a different directivity to a dome tweeter.
I avoid trying to describe how it sounds because describing it is like describing wine or chocolate- unless we can come to an agreement of what we mean, we are just using flowery language to try to convey what we mean...
Reactions: Arez
I'm not quite sure how to translate this description into perceived effects.. but knowing that cone drivers are capable of proper reproduction if used properly I can only advise against jumping to conclusions.
Try a planar mid some time. It is different. More different than any of the different drivers I have used. Hearing it was like the first time I heard a proper subwoofer in high school. Like an "oh, thats what it should actually sound like" sort of thing.
This is going back some time and I couldn't say.
Did you run it active or passive?
I don't know what difference that would make but planars do have interesting and useful diaphragm configurations and certain smaller details that can make them attractive. However if fundamentally they sound so different to cones, that sounds like a reason to avoid them.. but I'm sure that's not what we're trying to say here.
Seems Troels used this mid in a design.
Crossed at 700 and 2800. That seems usually high for the high pass and oddly low for the low pass. Unless I am missing some key piece of knowledge. My plan was to cross 200-250 hz lower and another 1khz higher
As you can see in the picture, the midrange starts to lose energy around the cross-over region. This is due to its off-axis response. You have to cross lower, and also use a tweeter that can cross lower - or use a waveguide - or else you will almost always get that reduction in the 2-5kHz region - just see almost all measurements from B&W, since around 1997.
An extended frequency response from a dedicated midrange, is a nice thing, but you still have to consider the whole speaker, in regard to baffle step, power response, sensitivity etc.
For example, I've noticed that moving from the cheaper KEF speakers, to the more expensive ones, you get less sensitivity, which could indicate that the smoother response of the more expensive - and better - models, are most likely better filtered than the lower level models, which could mean that they use more components in the filter to make the speaker more smooth and better over-all sounding. So, there is no free lunch. What you have to consider, is whether a given component in your design, gives you more fidelity, than it takes away.
Example from my system. I looked around a lot for the best woofer for my DIY speakers. Almost everywhere, I was shown how low they could play - often in a reflex cabinet. And this is often what people use these drivers for, so this is totally understandable. I just use a lot of energy to add subwoofers, which means that I actually do not need 30Hz from my woofers. Therefore, it was easy for me to use my woofers in a closed design, making the build smaller, also way easier to design/build.
Second example. When I looked for a midrange, I tried to find one that was as smooth on all axis' as possible. Dayton RS125 and SB Satori MW13TX being some of them. But I cross them at around 2000Hz to an SB 26ADC tweeter in an Augerpro waveguide, which leaves all break-up modes several thousands of Hz above the cross-over region. So even though many do not like the huge break-up in the harder coned midrange models. I would argue that you can get around it with the low cross-over point and a waveguide - hereby taking advantage of the smoother off-axis response from the more rigid cone.
So, the added "clarity" from these harder coned midranges, could actually simply be because I can make a smoother transition between the drivers - no lowering in the 2-5kHz region - rather than actually the harder cone being so-called more "resolving". But that's another topic 🙂
I am looking at these SEAS drivers to use as my mid for a little Kitchen 3 way.
There are two types. The woofer style which has a power limit of 60rms and sealed F3 of 170hz. This says it has the symmetrical drive. The Mid one doesn't say that but I assume its the same motor. I think this is the same motor tech used in the revelator and the wavecor drivers.
https://www.madisoundspeakerstore.c...e-ca12rcy-h1152-4.5-coated-paper-cone-woofer/
Then they also have this same woofer as "mid range". Now it has an RMS of 100 and sealed F3 of 105hz
https://www.madisoundspeakerstore.c...tige-mca12rc-h1304-4.5-coated-paper-midrange/
I'm going to buy the mid range of course. Since I am using it as a dedicated mid range.
But this begs the question: "what do they do to the driver to make it a dedicated mid range"?
Anybody know?
It appears they use a larger magnet on the midrange. I'm guessing this would move the QTS lower. I think these were designed to go together in a tall skinny enclosure.
But to answer the question, a midrange goes between the woofer and the tweeter. There is every possible configuration available from 12" cone midranges to 2" dome midranges. Some handle woofer ranges some handle high frequencies just under tweeter ranges.
30 years ago I had a similar dilemma, Seas 11FGX midbass or Seas 11FM midrange driver for 3way with with Scanspeak 21W8553 & Dynaudio D28AF. Same story as with these two new drivers. Chose of course 11FM for 400Hz/2.5kHz. There were other candidates for the mid range, but I chose this one on the advice of a friend. The first version was only 2way (8+1"), but I was not satisfied. Adding midrange was the right thing to do.
Reactions: Bmsluite
Anybody know?
Midrange frequencies are defined slighly differently depending on the table you use. This is just one example. Midrange is from 250 Hz to 2kHz. Above that are upper mids, some count that as mids too. So 250 Hz to 6kHz.
Generally, most 3way speakers, passive or active have 300 Hz to ~ 3kHz covered by midrange.
So midrange driver is supposed to cover this as flat as possible, with low distortion and minimum beaming. Low beaming is important for proper transition to tweeter.
Big midbass driver starts beaming too soon and require being crossed lower to tweeter, stressing the need for powerfull tweeter with low fs.
Ideal midrange is only 4-5" big. This has been discussed ad nauseam, no need to repeat it.
Reactions: Bmsluite
Legendary vifa was rather good midrange.
Another rather good midrange i used with hiquphon tweeter without crossover was this peerless. I think its on backorder or no longer available, like vifa. This could have been vifa replacement.
Notice lack of bass, ruler flat midrange, excellent of axis behaviour, almost no breakups.
Show me big midbass which can do this...
Reactions: Arthur Jackson
Wait, there is more...this is actually considered midbass, yes, it can do some bass. I made bookshelf with this aurum cantus which goes down to 30Hz. Not real bass, the cone is light and thin. But where it shines is midrange. Smooth, flat, goes up high enough to be crossed to ribbon tweeter, great of axis, almost no breakups. Used this one a lot. Not expensive, still available.
https://loudspeakerdatabase.com/AurumCantus/AC-130F1
What exact planar are you talking about?
I am very fond of planars, especially on open baffle, but i have yet to see one which would cover midrange. Most cover only upper mids. Those i used if crossed low distorted. Thats why i want to know which planar you used. Can you show fr response and distortion plots?
Many three ways have a crossover smack dab in the middle of the voice band and seem to work fine. It's not unusual to see crossovers to a midrange around 800-1,200hz. Most of these kind of speakers don't have earth shattering bass. I think it's a midrange if it covers 1.200-6,000hz rather than the much touted 300-3,000hz range.
I think what we are finding out is midrange is an overly generalized term just like woofer or tweeter. I use a midrange horn as a tweeter on my Econowaves. It's all very confusing.
Reactions: Bmsluite
Based on the X-over, it looks like he's using it as more of a "filler" driver than a traditional mid for a three-way.
