Pearl 3 Burning Amp 2023
Wow.
Wow, wow, wow 😍
This amp just sounds unbelievable gorgeous 😍
Diana Krall isn't in the other room, she is just here 😀
This amp has such an authority, powerfull bass, sweet highs... and the mids are to die for 😍
Many thanks to @wayne and all project participants!
(No noise, even without chassis. )
Have one P3 where the right channel blinks once at startup and have found it is related to the opamp connection. When loose it will cause this. Check all 4 smds carefully for continuity to their next circle -- this is easy. Do this and the wire/solder joints first.
My red LEDs also blink once when I turn the amp on. I have one PSU per channel, so I think it has something to do with the PSUs behavior. Another thread mentions a power-on transient, and I think that could be it.
Sorry if I expressed myself in a confusing way, I wasn't doubting it, I interpreted the blinking as an expression of this transient.
No, you were clear, just agreeing on the transient. Normally, one would turn P3 on first, then pre then power, making it no big deal.
Alternatively, if pre and power on, you would select mute, then turn on P3 also making it no big deal.
Like a big dummy ( omni dummy?) I flipped on P3 with BOTH pre and power in, AND had phono selected on pre....the resulting thump fried both channels in my XA 252! Like I said, totally preventable by proper switching order.
When I told this story, someone piped up about a known transient from P3 on turn on, and I accepted that as correct.....maybe mine (P3) has a problem? I sure didn't repeat the switch on problem!
Russellc
Reactions: Plott and mhenschel
I think the dual mono PS is a good idea. I just have standard "mono" power supply. Really like the custom cases from Modushop, but it isn't large enough.
Guess I could have them make faceplate and rear panel in a larger version chassis, problem solved.
Better order another power supply so it's on hand.
Russellc
Reactions: Plott
As others has noticed......
The "turn-on" "thump" is normal, and lasts shorter than a second.
If I switch the pre to "Phono" right after turning the P-3 on, I have a small DC-thump.
If I wait a second after switch on, no thump.
Also..... Both current LED´s blink once on startup, twice on turn-off.
All my builds were with different/various components. All behave the same way.
Thanks for the confirmation, @Boydk !
In the meantime I did a slight change in the feedback loop, I lowered R9 to 1.2 kohms in order to get lower gain, which means a total of 186 ohms when J2 is closed.
I just felt yesterday, that it was "too much", it was somewhat overdriven, but of course far from clipping.
Now it sings somewhat calmer, the "too much" has gone. I may check different R9 values between 1.2 and 2.2 kohms and set it to my liking.
Regarding hum... no, there is no hum, normally.
But one floor below me, a doctor has his large office, full of equipment. Yes, they're annoying... occasionally I get a humming noise, for a few seconds. So it's time for a chassis. Now I have to wait until 6 pm.
Reactions: wayne and Boydk
That confirms what Plott was saying. Like I said, the only "problem" I had was foolishly flipping it on with pre set to phono of all things
Russellc
