Alpha Nirvana 39w 8ohm Class A Amp
Here is my finished box front plate of AN39 .Now inside the Hiraga Le Monstre 4Ω version modules for listening.A rock steady amplifier at -/+ 24V bias 1.5A. +/- 1-2 mv offset. Very very transparency amplifier
Yurid.
Hi guys. My output offset voltage is -2mV without speakers. When I connect speakers it goes up to 34mV. Is this how it should be or is there something wrong?
Did you measure the voltages +/-27-28V and the bias again with the load speakers on it? Are the same ?
Off topic:
While X, Vunce, and Hugh are present on this thread, I have a request to have a look at the last couple of post's in the Yarra Pre/HPA for Melbourne GB thread and try to clarify for me, " why my DC voltage after the diodes would be 35V rather than 31V." Posts #1648 and onward have information also.
Thanks for the help, seems to be a stumbling block for my brain 🤔
MM
When I measure my AN39 with an 8ohm resistor or my speakers it remains the same: about 1-2m
Same story here with 4Ω , speakers
Yes its strange .
Yrid
If the voltages-bias remains the same with No load AND load then your speakers are difficult speaker's .What kind of speakers do you have? Are they electrostatic? I assume your measurements are repeated. and correct ones.
Why does such a defect occur at 14 volts at the output? The lower half-wave is cut off. Apparently I made a mistake somewhere. Current consumption is 1.34 amperes, supply voltage is +-26.5 volts. All components are in good condition.
