Alpha Nirvana 39w 8ohm Class A Amp
Today I finally changed the 820Ω carbon resistor in the gain with the 1.8kΩ carbon also.
And yes, I will really stay as is. Everything sounds better, voices and instruments.Without any sign of harshness, with enough detail in the voices, especially at high volume.
PSU +/-21.5V at 2.6A bias version 4R.
Thank you danny _66.
Hi, take a look at this post:
Reactions: Yurid
R141 and R142 have been discussed previously in this thread (first 10-15 pages where X did a multitude of measurements and experiments). These are the source resistors for the output stage MOSFETS. They do have an influence on overall sound and distortion. In these positions I am still experimenting but I have chosen Riedon FPR2 series which have a copper magnanin foil that is seen in some expensive resistors of the Vishay VPG division. Values here can be 0.18 ohms to 0.25 ohms. Of course at lower values, bias current is higher and vice versa. At 0.25 ohms, my bias current is ~ 1.35A. I plan on trying 0.22 ohms in the future but the only value that was in stock at the time of purchase was 0.25 ohms.
I could use some help here as I am trying to place my parts order, and am hoping to keep things within 2 suppliers. Mouser and Parts Connexion have almost everything I need other that the KOA Speer BPR58CR22J, which was preloaded in the BOM cart for Mouser for R141/142, and is currently backordered. Can anyone recommend a suitable replacement at either of my preferred suppliers?
EDIT: I think this should work! https://www.mouser.com/ProductDetail/KOA-Speer/BPR58CFR22J?qs=1He0yLMpldCZL5xQ2oQYLQ==
You can add a high quality film cap to bypass C124 like 2.2uF MKP.
Can someone please explain this to me like I'm 5?! I'm in the process of ordering parts, and have chosen a Panasonic FM Series 470k 25v cap for C124, and came across this post. I'm not really familiar with the concept of bypass capacitors, and in trying to do some research I just got more confused as there is SO MUCH information across many different specific categories that I just got more confused than helped... at the end of the day I just want to know how exactly i might do this, and maybe get some additional information on any specific recommendations for the 2.2uF MKP caps... Sorry for the N00B questions, but I'm trying to learn!
Because bypass capacitors reduce noise and stabilize the power to the design. Audio amplifiers achieve reduced distortion and improved audio quality.
Add in parallel a small film capacitor across a much larger value electrolytic cap. Larger capacitors tend to have higher inductance and dielectric absorption affecting higher frequencies the most. Bypassing with smaller capacitor (creating alternative path at high frequency) improves overall performance. It also allows to use cheaper main capacitor for cost reduction. Huge electrolytic caps (with higher inductance) in power supply seems to be ideal target for bypassing (speaker current closes thru them), but low ESR bypassing caps in parallel with inductance of main caps can create parallel resonant circuit.
I suggest to follow the standard schematic if You're doing it for the first time 🙂
Thank you! This is very helpful.
@Gthibodeaux , If you are going to make statements like you have above, please attach or quote the image or words and where you found this information. I have spent about 1/2 hour looking at various schematics posted trying to help you, and the schematic above in post #3707 is the one that I would use.
MM
I am seeing in the Mouser cart 2 MELF caps that are marked R1001 (100R) & R1002 (47R), which I'm guessing are the snubber components. That said, I guess I just don't know if the R101 & R102 resistors listed in the BOM are erroneous and should be ignored, or have been mislabeled and belong somewhere else on the boards...
Hi guys. My output offset voltage is -2mV without speakers. When I connect speakers it goes up to 34mV. Is this how it should be or is there something wrong?
What a very interesting discovery.
I only have ever measured (and adjusted) DC offset with no spkrs attached ... so I can't help you. 🙁 (You're obviously higher up the OCD scale than I am! 😀 )
@Hugh?
