Easy-to-build I/V stage
regarding the simulations
tschrama
if you replace the ideal voltage source biasing your
Q3 base in the "cas" schematics with real world
sources, such as resistors, diodes zeners etc, you will find that
the distortion will be more realisitic ie higher.
Yv
I think you'll find IV stage bjt and cas2, the ones with both PNP and NPN transistors isn't going to work very well. The bias through the input transistors will be virtually impossible to set and get stable unless you put resistors at the emitters but that raises input impedance.
Spying on me again, eh, Elso?
The reason why I came up with my top-secret I/V is that I was using AD846s for them in several designs. Sounded great, but only up to a point. And the point was that the dealers hated them. So........get rid of the feedback, and voila!
Yes......I know.....I keep saying it.......current-feedback stuff sounds odd. Don't know why.
As for being stable..........then how do things like the AD844/846, and all those other similar ICs work. Yeah, I know.......matched parts on the same substrate, etc. There are ways around it.
Jocko
Many people already tried this topology. Here is some good reading from one already tried this.
It is in fact a common base circuit. One note of caution: A small parasitic capacitor from the emitter to ground will definitely turn this circuit into a hf oscillator. Depends a bit on the emitter bulk resistance and Ft. Who was saying this circuit has no feedback? Although a DAC-chip is current out, most have a pretty low output resistance in the order of 1K, take it into account. It interferes with input resistance at the emitter. The current flowing into the emitter modulates its resistance. For low distortion, the current trough the bias diode at the base should have the same current flowing trough it as the emitter that is driven at ALL signal levels and the construction should preferably be build with matched pairs.
If you want to investigate this further, have a look at the BurrBrown OPA660 “diamond” transistor. PSpice model is available :bigeyes: Looks promising, but no idea how it sounds.
I thought the Bordeaux-Claret was the best one. Until Phred blew the punchline.
Hey.....I didn't put 1 Megohm there.
Thanks to Pjotr for the link. Glad someone is paying attention. Even Barrie Gilbert (Gilbert Cell fame) says that an op-amp is the worst thing you can put after an R-2R DAC.
Jocko
Joined 2002
What is the reason for the oscillation when a cap is connected at the emiiters at the input?
If the base of a transistor is driven by a nonideal source, (ie some resistance in series with the base) the emitter looks somewhat inductive to the circuit attached to it. In other words, the impedance looking into the emitter increases with frequency. Keep in mind that even if you nail the external base termainla of the transistor down with a solid low impedance, there is internal base resistance.
The effective inductance is approximately Cpi * Rpi * (Rb/Beta), where
Cpi = Tf/Gm, Rpi = 1/Gm, Gm = Ic/Vt, Vt = kT/q = 26 mV at room temp, Ic is the collector current, Rb is the total internal+external base resistance.
The total output impedance can be estimated as this inductance in series with an equivalent "resistance" of 1/Gm+Rb/Beta, and the LR series thing appears in parallel with Rb.
So the upshot is you have someting like an LRC circuit at the emitter, with the transistor acting like a fake inductor. Hence the possibiliy of resonances and oscillations.
To understand this intuitively, remember that the base-emitter junction stores a lot of charge, and so it acts like a capacitor. The charge in this junction determines the current flow in the transistor. If you feed the base from a resistive source, it takes time to charge and discharge this base-emitter capacitor, so it takes time to change the current flow in the transistor. Which is exactly what an inductor does; you can't change the current flow instantaneously in an inductor, inductor current varies slowly.
Does this make sense?
diyAudio Retiree
Joined 2002
JOCKO'S BEST POST EVER and Spice
I believe Jocko's point was that the output of a DAC chip is not an ideal current source but has much lower output impedance than 1 Megaohm. And I would bet money that he has measured this.
Too high an impedance in the Sipce model will act as an unrealistic amount of emitter degenaration and give even lower distortion in the Spice model. I don't know why everyone keeps measuring distortion with Spice as it gives meaningless numbers due to the simplified models used for transistors. I am wasting my breath with that statement I know but someday......
Go build one of the simple Nelson Pass or Erno Borbely circuits from the websites and compare thier measured distortion with the numbers that Spice gives you. I guarantee the discrepency is not due to Nelson or Erno's measurement techniques.
the Spice is quite nice
but it is best to make test
to find out the rest
Haiku.... by who?
Fred
P.S. Thanks go to Poet Warrior Zen Master Pass for the gratuitous Haiku inspiration
Please will you stop whining about PSpice everywhere that comes up in a thread. It is of no use to blame PSpice and people investigating it that YOU get meaningless numbers out of it. Hopefully someday….. you get meaningful numbers out of it too.
I dare to say that you can even predict how an amp will sound, once you manage to use it the correct way. But only if you correlate the results in the correct way with your real life hearing experience, your measurements results and what is already published over the last 50 years about what makes an amp sounds as it sounds.
For those who get rubbish out of it, don’t give up. One day you will recognise why it generates rubbish and why the results do not correlate with the real thing. Then it will start to be a great helpful tool. It helped me a lot to get rid of problems that cannot be isolated in real life. But you need to be aware of the shortcomings of modelling in general and how to handle it and interpret it. That is also called “Learning”.
Use with PCM 1738?
Jocko, etc.
How would you configure this circuit for use with a DAC like the PCM 1738 which has 2.5 volts DC on its current outputs. Would you bias the input transistor on its base so there would be 2.5 volts on the emitter? Of course you would use two of these circuits for plus and minus and then sum them through a transformer or other circuit, or just use it single ended. Anyone?
Ric Schultz
