Simplistic mosFET HV Shunt Regs
Well Salas definitely is the PSU, the SSHV2 is feeding a cascode CCS as anode load, so to be sure isn't the SSHV2 I disconnected the SSHV2 and connected directly the raw PSU to the cascode CCS as anode load to see whats the max. mA can I get and summing both channels are 36mA clearly raw PSU doesn't reaches the 60mA that needs the SSHV2 to power the cascode CCS as anode load for 20mA for each channel.
Do you know if increasing capacitance at raw PSU could increase these 36mA to 60mA needed?
Tried with Q1 with strong VDS, 1st atempt fuse between raw PSU 0,25A KO, 2nd atempt see picture.
Reactions: Salas
This SSHV2 was regulating a couple of 4P1L headphone amp from raw PSU B+ 340V to 200V after SSHV2 output, TP measured 1,1V so 110mA, load 80mA without any problem.
KO when connected to a raw PSU B+ 340V with a load of 34mA, load are a couple of cascode CCS set to 17mA each channel working without issues without SSHV2 direct raw PSU to both cascode CCS.
Any idea was happening Salas?
I forgot to tell you that I use in place of Q3 IRF840 the SIHP8N50D-GE3 mosfet N-CH 500V 8.7A TO-22 because when made the IRF840 was out of stock & with long delivery time so you told me to use the SIHP as equivalent.
