Plethora of Pinjatas / SET P amp(s)
same SL OS both
M25 - SE input only, autoformer based FE, No NFB, gain either 4 (Cinemag, Jensen classic repeaters) or 6 (Edcor 600:15K), mild THD, dominant 2nd neg
PoP - active FE, both SE and Bal input, NFB yes, gain - forgot ........ aha - 100K/10K, loow THD, dominant 2nd neg
sound - all my amps are sounding the same
:rofl:
other OS parts - they will work, but with slight difference, if there is a difference in xconductance, comparing to originally used
slight - no night and day
though, clever to use mosfets in output, as is constructed ........... TTC/TTA are bipolars
availability - you're practically just one personal message away of knowing how
Reactions: Russellc
A close friend of mine liked the Mini so much that he wanted one too.
I hope he will like the outcome 😎
matter of principle - if sending wires though metal plate, always do it in "natural pair through one hole" fashion, using grommets
example: [L & N] wire through same grommet-ed hole
example 2: [+, GND, -] through same grommet-ed hole
btw. which amp is that?
if PoP, I'm glad seeing someone else's pcbs
I'm famous!!
:clown:
Reactions: Jacruzer787
So far so good, hopefully. Here's boards, no ccs board yet, but thought I would post for more eyes to find my ook ups. Did I leave anything out?
This is standard P of P, not set version.....
TIA,
Russellc
yup for everything
I believe you got separate sch files in fileset I sent you, so just strictly follow one for straight MOS
I mean, I don't remember, but it's logical that I did
for start, while setting Iq, no jumper across cap in negative input leg, only later
Checking file set, only notes are what parts to exclude, short S101 and what resistor to use in another position. Dont see any other notes, although
I do see two additional tabs on that note file, unfortunately they had nothing in them. I went through the other files, I could just be too dense to locate, but seems logical they would be in the "notes" part.
Russellc
Note:
Plethora of Pinjatas, DO NOT MOUNT:
DO NOT MOUNT ZD103, R142, M101, R144, R149, Q109, R143, R145, R146, T108
R147=100R
SHORT S101
Plethora of Pinjatas_SET: MOUNT all of above
R147=750R
OPEN S101
  • Plethora of Pinjatas_SET parts placement.pdf
  • Plethora of Pinjatas_SET NOTES.txt
