DAC AD1862: Almost THT, I2S input, NOS, R-2R
Guys, why now the moode with amanero clone is giving me a cracking and popping sound? While on USB out of phone is perfect... Settings are i2s DAC (tested all the 3 choices) and amanero combo as driver... Can't find a reasonable reason for that... Perhaps something is wrong in some interface?
There are other types; 1SMB5934BT3G, 1SMB5934B-W, 1PGSMB5934,CZRB5359B-HF..... Calculate that this diode will have about 300mW of dissipation, so give it a little more copper surface area.
As for 10nF/400V, you have FCN1913G103J-E3 and SMDTG02100TA00MQ00.
It would be a good idea to put a decoupling capacitor at the regulator input, for example 0.1uF/400V (CB162I0104KBC). You can make the PCB so that the capacitors are TH as well as the power resistor and everything else is SMD.
here we go :
big resistor and 2 capacitors are now THT, diode corrected, added decoupling cap
  • Grunf_HV_REG_BOM.xlsx
  • Gerber_Grunf_HV_reg_(180V)_PCB_Schematic_2025-01-12.zip
This D1 uses 2SK2013 in place of the IRF510, they have a different average Vgs and the stock resistor/pot value wasn’t able to pull the gate to zero, an adjustment of the resistor between ground and the pot from 10K to 4K7 gave the needed adjustment to achieve 0vdc on the input.
Sounds beautiful.
Thanks to @Sorenm for the PCB. 👏
Reactions: Sorenm
