SilentSwitcher - mains-free +/-15V and 6/5/3.3V power
Silent switcher fit nicely in a tight space for a Pearl 3. The 15-volt regulators were removed and in/out pads Jumper'd. It is very quiet. Only had a brief listen so far.
Regarding load capacitance on +/- supply what Jan Didden stated about the original SilentSwitcher applies also to the new one:
https://www.diyaudio.com/community/...ee-15v-and-6-5-3-3v-power.297147/post-6616614
Large load capacitance (above 500uF) may cause high inrush current and does not actually improve performance. SilentSwitcher has sufficient decoupling at +/- output. Small load capacitance (e.g. 10-220uF) can be added if needed.
The output connectors provided with the boards are Molex KK254 series. These are polarized to prevent misconnections.
Here are Mouser part numbers for the matching plugs from Molex:
2-pin plug: https://www.mouser.fi/ProductDetail/Molex/22-01-3027?qs=cRUT3GdJqnwywyFd19%2BSsA==
3-pin plug: https://www.mouser.fi/ProductDetail/Molex/22-01-3037?qs=cRUT3GdJqnw5IA1z0J2xqA==
Pin: https://www.mouser.fi/ProductDetail/Molex/08-51-0108-Loose-Piece?qs=8%2Bu/V6/T1OrE67rmlr2KVw==
A crimping tool is required. I use this type:
https://www.partco.fi/en/tools-and-handtools/crimp-tools/rest-of-crimp-tools/11353-ht213.html
Reactions: deburgh and lung
Those connectors are already in parallel so each connector (or both together) has the same current capability.
By changing resistors it is possible to have +/-30V output from those connectors but available current would be lower. I have tested the boards with +/-24V output and available current was at least 200mA. Input voltage needs to be at least 9V, preferably 12V or even 15V.
Reactions: jan.didden
