TPA3255 - all about DIY, Discussion, Design etc
I tried implementing it on my TPA3255 amp. I took two 33pF C0G caps (66pF total) rated for 2500v and paralled them at the output pins. Then used tiny wire wrap silver wire to connect to the chip resistor closest to the TPA3255 input pins. This was done for 4 of the outputs and amp is running in BTL stereo mode. Will look at Oscope trace and add another 33pF if needed.
Reactions: xschop
You could install the capacitor with a short end of wire (to the input) and use some shrink tube to protect it. So you dont have to place them at the bord, making installation much simpler.
I only ask my self why TI has not mentioned this way to improve the output signal.
Great long thread here. Thanks for sharing :up:
Just started my own design of a TPA3255 implementation.
Intention is to do a prototype/POC of just the amp section, before integrating a ADAU1701 to forma 2 channel plate amp. Think I can fit it all on a 10x10cm 4 layer to stay cheap at JLCPCB.
As for Post Filet FB there is the suggested design by TI here:
https://www.ti.com/lit/an/slaa788a/slaa788a.pdf?ts=1735744921637
You are probably all aware, and it is probably already referred here in the thread somewhere.
Certainly I studied these files. But a ref design is primarily intended to verify manufacturers data.
So it should be considered the STARTING point - and not the endpoint - of any development.
In those days one of the TI developer team was writing on this forum and I contacted him.
A danish guy, sadly I lost his name.
We discussed ways for post filter feedback, and although he liked my approach this was too late as the development project came to its end("hire and fire...")
In other words, there may be room for improvement
Reactions: xschop
Hi bucks bunny
Fully agree 🙂
(the post was also mostly intended for more readers to take a look at the app note 😉 )
A single cap will "only" give further FB at higher freq.
The approach in the app note gives overall 5 dB FB.
A drawback is the lower overall gain, but that's of course just the backside of FB 🙂
So you'll have to add more gain in a pre-amp stage to make it work with normal pre in level (0.775V RMS).
An approach could be to include an opamp in the overall PFFB loop. Alternatively just a good opamp stage.
Overall I fully doubt anyone can really hear any difference with a 5 dB decrease of THD.
As you have also shown the most important improvement is the reduction of the peak in the freq response at higher freq caused by the output filter.
But if you want performance like shown by 3e Audio, you'll need the extra FB 😉
Hi bucks bunny
Fully agree 🙂
The reduction in noise would be very important for a nearfield application
Reactions: Baldin and xschop
The TPA3255 without PFFB and a good PSU had very low intrinsic noise. One of the quietest amps I have measured. I can press my ear to the speaker cone and cannot tell the amp is on. PFFB reduces the THD, but the background noise is already low.
This is the measured noise floor on my amp without PFFB using a MicroAudio SMPS650-SO PSU.
Reactions: xschop
