100W Ultimate Fidelity Amplifier
Hi
This is what I see with JLCPCB
Looks ok to me but maybe someone can confirm before I order 5 PCB.
I’ve just noticed 2 little jumpers near the middle of the PCB, these were probably there on the original single sided PCB. I’ll probably replace them by 0 ohm power resistors.
Eric
Reactions: quadtech
Apex AX14 - 2pairs.
Respected Sir,
I'm having issues with dc offset.
In the Left channel I am getting dc offset 6mv, while in the right channel it is nearly 0mv. Both channel bias is set to 16mv.
Rail voltages are +/-56Volts, input+ SGND are connected to PSU GND while taking these measurements
As I went through this thread, dc offset readings seems to be fine in my case (please correct me if I'm wrong).
But I'm also looking for your expertise advice why I'm getting two different results, and how to get same readings for both the channels.
Reactions: priyank
7 mV is quite low no problem.
transistor differences can be the cause, like in the input, and need matched.
I have a servo who do also not exact 0 mv, here op amp is cause, can use a
precision one but 4mv in mine case is quite oké.
if it drifts then there is something get warm, or is you have current feedback
drift is present without measures like mine with a servo, I have open loop
hybrid by the way, tube are dc coupled to mosfets so a servo is needed and
a long delay before the relais shut speakers on.
regards
Hi Indian members,
i have about 20-30 pcbs of attached apex preamp and psu which i want to get rid of.
only shipping and packing charges of inr 200. payment by g-pay. interested members can contact me via pm with qty required and postal address.
i have used it over a year and works well. no support for build will be provided. All values provided on sch and also on pcb..
regards
prasi
Hello Prasi Ji,
Do You Still Have This Board..
Here is the layout provided by Alex. It had a few extra holes to provide for different style components.
hi, i made this pcb. it seems to work but i have noticed that one or two of the transistors on both sides get too hot. i will recheck exactly whith one is heating and why. i think it happens when ground is connected and i have noticed some distortion in audio too.
Reactions: rolf101
Hi I checked the board and found that 220 ohm resistors on both positive and negative side is heating up. I used BC 557c and BC 547c in replacement. Transistors connected to 220ohm resistors are also too hot. One more thing I noticed that there is 5v at output. I'm thinking to rebuild but it's gonna take time
because i am interested about the Apex AX-14 amp i made a pcb with Kicad. There are little changes on the board. I want to use a Connex SMPS and i set two 470 µf capacitors and two 100nf caps. Could be changed to 22 µf, without the 100 nF.
Instead of Q1/Q2 2N5401 i changed to BC560 with different pinout. Groundlift resistor is on the pcb.
I am not sure if the zobel is right, choosing 10 Ohm/100nf. Also the boucherot filter choosed with 1 µH and 10 ohms.
But i can easyly correct that components.
Question to Apex, Mr. Mile...is it allowed to post the gerber files here?
This is the first try to design a pcb for the AX14. Perhaps i will make some changes....
If you find any mistake or i can do something better, please let me know...
Greets Peter
